Computers & Internet Logo
l
linda Posted on Mar 13, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can find the on screen display button - eMachines Computers & Internet
Rob Woolcock
Level 2:
Sergeant:
  • Expert 289 Answers
  • Posted on Mar 22, 2016
Rob Woolcock
Expert
Level 2:
Sergeant:
Answers
289
Questions
Helped
69724
Points
733
Usually under the front edge
How to remove the icons on the JVC digital camera GZ MG 37 AH
To remove icons from the display screen on your JVC digital camera model GZ MG 37 AH, you will need to follow the specific instructions for your camera model. Here are the general steps you can follow to hide or remove icons from the display screen:
  1. Press the Menu button on your camera to access the main menu.
  2. Use the arrow buttons to navigate to the "Display" or "Setup" menu.
  3. Locate the option for hiding or removing icons from the display screen. This option may be called "Icon Display," "Screen Display," or something similar.
  4. Use the arrow buttons to select the option for hiding or removing icons, and then press the OK button to confirm your selection.
  5. Use the arrow buttons to navigate through the available options for hiding or removing icons. You may have the option to hide all icons, hide selected icons, or show all icons.
  6. Select the option that best meets your needs and press the OK button to confirm your selection.
  7. Press the Menu button to exit the menu and return to the normal display screen.
How do i upgrade firmware of sharp mx2700n copier
To update the firmware, set DIP SW 2 on the MFP control PWB to ON.
1) Insert the USB memory into the machine.
* When USB is not connected, "INSERT A STORAGE FIRMWARE STORED ON" is displayed. When [OK] button is pressed, the display is shifted to the folder or file selection screen.
2) When a firmware update folder or file button is pressed, the display is shifted to the firmware update screen.
* The number of buttons depends on the number of files in the inserted USB memory.
A folder name or file name is displayed on the button.
If the folder name or file name is of more than 34 characters, only 34 characters are displayed.
For a folder name, "<DIR>" is displayed at the head.
* When [ .. ] button is pressed on the file selection screen, the display is shifted to the folder or file selection screen. On the folder or file selection screen, the keys are disabled.
* The path of the folder or file is displayed on the title section.
If the path is of more than 50 characters, only 50 characters are displayed.
Read more >> http://electrohelponline.blogspot.com/
Change the display name?
Administering a 1400 Series Digital Deskphone
Perform the following steps for each 1400 Series Digital Deskphone:
1. Log into the Avaya Aura Communication Manager administration interface.
2. Perform one of the following steps:
? If you are adding a new extension and want to assign a specific extension number, use
the add station nnnn command, where nnnn is the new extension you want to assign.
? If you are adding a new extension and want to assign the next available extension
number, use the add station next command.
? If you are installing the 1400 Series Digital Deskphone at an existing extension, use the
change station nnnn command, where nnnn is the existing extension you want to
modify.
The Station screen appears.
3. Perform one of the following steps:
? If you are administering a 1408 telephone, type 2410 in the Type field.
? If you are administering a 1416 telephone, type 2420 in the Type field.
4. In the Port field, type the port address.
5. In the Name field, type the name to associate with this telephone. Administering 1400 Series Digital Deskphones
20 Avaya 1400 Series Digital Deskphones Installation and Maintenance Guide
6. Configure the remaining fields on the Station screen pages. Keep in mind the following
information:
? If you are administering a 1408 telephone, the first eight call appearance/feature buttons
displayed on the Station screen are administered on the 1408 telephone. (Since the 1408
telephone is aliased as a 2410 telephone, the Station screen displays 10 call
appearance/feature buttons.) The remaining buttons displayed on the Station screen are
not administered.
? If you are administering a 1416 telephone, the first 16 call appearance/feature buttons
displayed on the Station screen are administered on the 1416 telephone. (Since the 1416
telephone is aliased as a 2420 telephone, the Station screen displays 20 call
not administered.
? If you are administering a 1416 telephone with a DBM32 Button module, the first 16 call
appearance/feature buttons displayed on the Station screen are administered on the
1416 telephone. The remaining eight call appearance/feature buttons displayed on the
Station screen are administered on the first eight buttons of the DBM32 Button module.
The 24 buttons of the EU24 expansion module displayed on the Station screen are
administered for the remaining 24 buttons of the DBM32 Button module.
For more information about administration and features, see:
- Administering Avaya Aura™ Communication Manager, Document Number 03-300509
- Avaya Aura™ Communication Manager Feature Description and Implementation,
Document Number 555-245-205
- Avaya Aura™ Communication Manager Screen Reference, Document Number
03-602878
7. When finished administering this extension, save your changes.
Online Virus Removal 39 99 Online Virus Removal and Online PC Help
Screen wont display
Just right of the bottom of the screen there is a little button called display. If you press that button during recording mode, you can cycle through different information on the screen. One is NO DISPLAY. others are like just the frame you want to tale a picture of, one is with the picture and information about the light, one with lines and so on. Just press the button several times to cycle through all these displays. It is on page 61 of the manual.
Sony bravia picture to large for screen
Sir press the screen mode button in your remote below input select button, press the screen mode button repeatedly to select smart, 4:3, wide, zoom, or 14:9.
  • Smart- Display conventional 4:3 broadcast with an imitation wide screen effect. The 4:3 picture is stretched to fill the screen.
  • 4:3- Display conventional 4:3 broadcast non-wide screen TV in the correct proportions.
  • Wide- Display wide screen 16:9 broadcast in the correct proportions.
  • Zoom- Display cinemascopic letter box format broadcasts in the correct proportions.
  • 14:9- Display 14:9 broadcasts in the correct proportions. As a result, black border areas are visible on the screen.
HOW DO YOU RESET YOUR PRINTER
  1. Press the "Fax Mode" button.
  2. Press the "Menu" button. The "Fax Menu" screen will be displayed.
  3. Press the down arrow button 9 times until the screen displays "Maintenance."
  4. Press the "Select" button. The screen will now display the Maintenance Menu.
  5. Press down arrow button 4 times until the screen displays "Restore Defaults."
  6. Press the "Select" button and a new screen will pop up. "Are you sure
    that you want to reset default settings to their factory settings?
  7. Press 1. A new screen will pop up that says the factory settings have been restored.
I am trying to set my Sanyo picture right side up. what setting do I go to?
Check Ceiling feature.
Press MENU button and ON-SCREEN MENU will appear. Press
POINT LEFT/RIGHT button(s) to move a red-frame pointer to
SETTING icon.
Language used in ON-SCREEN MENU is selectable from among
English, German, French, Italian, Spanish, Portuguese, Dutch,
Swedish, Russian, Chinese, Korean and Japanese.
Display
This function decides whether to display On-Screen Displays.
On ··· shows all On-Screen Displays.
Off ···· sets On-Screen Displays disappeared except;
? ON-SCREEN MENU
? "Power off?" message
? "No signal" message
? "Please wait...."
? P-Timer counter
Set a red frame pointer to item and press SELECT button.
Press POINT DOWN button to move a red-frame pointer to item
that you want to set and then press SELECT button. Se ting
dialog box appears.
Remote control not working with tv
The remote control is an acess to the TV device for example only from a distance. A remote controll for functionality would require to insert batteries a power source making possible communiction with devices requiring reception transmittion of signals. The remote is handheld pointed to the direction of TV requiring signal before button pressed woudl achieve response. a common button to start the remote control experience is pressing on the power button, that displays a signal on the TV. The TV should momentarily produce a sound and lighting effect,, and displaying on the dark screen a light blue screen. The initial signal response from remote control to TV indicates devices are functioning as required. Additional buttons on the remote controll could perform functions of several available.
The remote control has master button, menu on which every additional function is deriveable. Once the menu button is pressed with remote pointed in the direction of TV, should dicplay a list of options on the blue screen already established by power button. Every additional remote control device functionality is achievable by only after the first two buttons have been powered and pressed to display option results on a screen of TV. The remote controll buttons remaining perform complementary functionalities. For example, the arrow keys on remote control make movement of the options displayed on the screen, where a comfrimation button or identified as select allows to confirm remote functions displayed on the screen. A remote control could have several functionalities only accessible once made to display in screen. The three most common buttons on a remote control are First power button that powers on the TV, menu button that displays a list of functionalities on the powered on bl;ank blue screen, and using the arrow buttons on the remote would moves an indicator arround the screen area options. The selection button makes confrimation of the option.
1. Create a message box in Win32 programming, on
yaddu khud kar le bhai aasan hai
mridul
Top eMachines Computers & Internet Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
