King Chambers,
It would be optimal to have subwoofers that are Dual 4 Ohm. However I am going to tell you the most optimal way to hook up the combination you have to extract the most power out of your amplifier.
You will need to wire each subwoofer in series by taking the positive from one coil on the subwoofer and connecting it to the other voice coil on the same subwoofer; then take the left over positive and negative and hook that to your amplifier.
You will do the same with the other subwoofer. This will give you a 2 ohm load. If you had dual 4 ohm coils then we could get you down to a 1 ohm load.
SOURCE: ohm load???
You can't wire a pair of single voice coil 2ohm subs to achieve a 2 ohm mono load. Too bad you don't have 2 four ohm SVC's. Sorry
SOURCE: how can i wire the dual 1.4 ohm either to a 2ohm
more than likely it will overheat at .5 ohm
