Kevin, As Randy O. points out not an easy fix. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
You can open the rear hatch, and the area where the jack is located on the driver's side, open that cover and look inside the panel up towards the front, you will see the anti-theft system with the information on it.
The anti theft is designed to be permanent. Or else any thief could disable it and steal your car. Here is a link with info and the best ways to bypass it. http://vatspasslockpasskeysecurityhelp.yolasite.com/
more info please ..but can you open other account or just your face book account ? try changing your security settings and it think its not on the router but the ISP settings if so .. try contacting them for more info
or try contacting the admin in face book 1 check first did you do something to break the agreement>? did you received any warnings from the admins ? have you opened you FB acc on other computers? did you share your password w/ others? and have you offended someone in face book?
these are the main reasons why the account gets disabled in facebook
here are the link where you can ask for restoration =D hope this helps
If
this is the first time you are having this issue it is possible that
the playstation network may be down. If not try manually
configuring your PS3 IP info. You can also try disabling medai server
connection in
the PS3. The link below will bring you to a form with a more detailed
resolution. Scroll down the the bottom of the form for the info needed.
