The channels flash through and then stop for a bit
Gustav, Try factory reset, to get to the Setup Wizard. With the TV on press the menu button on your remote. While the menu is displayed press the 0 button four times. This should bring up a new menu with factory reset as an option.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.hdtvsolutions.com/pdf/27w7_32w6_37w2uMan.pdf
Westinghouse LTV 32w6 User Manual
How do you factory reset Westinghouse lcd tv AskReddit
http://www.avsforum.com/forum/166-lcd-flat-panel-displays/678671-new-offical-westinghouse-ltv-27w7-ltv-32w6-ltv-37w2-thread-87.html
The tuner section has a problem and needs to be addressed.
How would you access the tuner section? I am having issues finding the tuner, if it works, what type (qam, ntsc, atsc) as my tv is used (manf april 2015- westinghouse) and I am not prompted to enter the activation code for the tuner even after factory reset from the factory menu. Are there are other menus/ settings? If so, how do I access them?
Your tuner is unstable. All U need to do is find out what board has the tuner circuits and replace board if cost effective.
