The wire feed motor works.
SOURCE: have a 110 volt mig wire feed. motor slows to a
To get parts for your welder you'll need to have the serial number off the tag on the case. This problem could have other causes, have you:
Checked the tension on the wire spool? You ought to be able to pull the wire by hand easily.
Checked the tension setting on the pinch rollers? Too much tension can drag down the motor speed.
You could also have a bad control card depending on which model wire feeder this is.
Regards,
Carl
SOURCE: wire feed not working wire feeds through the
Does it have a feed adjuster ? its like a clamp over the wheel that applie pressure to the wire in order to push it through the line!
always deburr the line when feeding it into the tube!!
cheers rob
SOURCE: hobart handler 135 feed motor for wire doesn't
check the SCR ,looks like a big transistor mounted
to a heat sink or some of the older units had a relay
in-line with a fuse , I have a older Hobart and it is
a great little welder. If you snap a pic of the P.C.
board and email it ill [email protected]
point out what parts to check.and replace.
Rob
SOURCE: I have a hobart handler 120/90amp wire feed welder
I have welded countless hours with Linde & Lincoln & even a few Hobarts & the only time that I ever had the same problem was when the ground connection either to the object I was welding, or the welding cable ground wasn't good & clean & tight. Same on stick welders also. I did develop the habit of grinding not only where I was preparing to weld, but where I was placing my ground clamp & that always provided a better "frying bacon" sound as I went along the business of pushing a bead. In a welder, the only other thing than that is involved is the step-up transformer and your wire. Hope this helps.
