Hola, mi POLAROID PDR 300 al reproducir se corta la reproduccion apenas empieza y el equipo queda apagado con la hora en pantalla. alguna idea? gracias
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Hola a todos, el grabador tiene los controles en dos circulos debajo de la pantalla, en el de la izquierda, con el grabador ENCENDIDO, debes oprimir unos segundos el boton rojo del centro que dice ERASE, y aparecera la leyenda DELETE ALL titilando 3 veces, y luego dice FORMAT, tambien titilando. En este momento oprimimos nuevamente el boton ERASE y el grabador comienza a formatearse, en la pantalla aparece el mensaje WAIT, por lo que esperamos a que termine el proceso, y LISTO!!!, cuando lo vuelvas a conectar a la PC te reconocera las 4 carpetas. Tambien yo lo formatee con la PC y estuve varios dias con este problema. Pasa que luego de un tiempo de uso, y aunque vayas borrando las grabaciones que hagas, la memoria se ocupa totalmente y te pide el formateo. Espero que te haya servido. Saludos desde Buenos Aires
puede que haya un falla con la fuente de poder, con la tarjeta madre o con la toma de corriente en donde se esta conectando el router.
intenta conectar el router en otra toma de corriente
espera algunas horas y vuelve a intentar.. tengo un router dlink que a veces deja de prender y despues de algunas horas de estar desconectado al reconectarse vuelve a funcionar, no es normal pero pueda que la condicion o el fallo solo sea temporal
si el router tiene menos de 1 ano pide reemplazo bajo garantia.
tal vez el boton del flash esta en off apagado o en automatico y esta en un lugar con mucha luz por eso no se acciona busque en el cuerpo de la camara el boton del flash y accionelo hasta que se prenda o se ponga el dibujo en la pantalla de el falsh
éstos son algunos procedimientos que se pueden tratar de resolver este problema con la línea blanca de la pantalla. Pero,
por favor tenga en cuenta: si estos 2 procedimientos no ayudan, te
recomendaría tener en tu Mac en el servicio de Apple en un centro de
servicio autorizado
éstos son algunos pasos que usted puede tratar de resolver el problema:
Opción # 1
-PRAM reset -
En primer lugar, sostiene en su botón de encendido durante
aproximadamente 10 segundos para hacer una parada difícil, si no se ha
cumplido ya su Mac apagado.
• Una vez que tu Mac está apagado, usted tendrá que realizar lo que se denomina un restablecimiento PRAM (RAM de parámetros)
• Busque las siguientes teclas en el teclado: Comando, Opción, P y R. Es necesario mantener estos teclas simultáneamente.
• Encienda el ordenador.
• Mantenga pulsado el Comando + Opción + P-R llaves. Debe pulsar esta combinación de teclas antes de la pantalla gris.
• Ahora, presionando las teclas hasta que el equipo se reinicia y se oye el sonido de inicio por tercera vez.
• Suelta las teclas y permitir que el MacBook a poner en marcha.
Opción # 2
-Restablecer la PMU -
El administrador de energía es un circuito integrado (chip de ordenador) que suele ser en la placa lógica de su ordenador Mac.
Es responsable de la gestión de energía de la computadora. Controla
la retroiluminación, giro del disco duro, el sueño y la activación,
algunos aspectos de la carga, control de trackpad y algunas entradas y
salidas en relación con el reposo del ordenador.
• Si el ordenador está encendido, apágalo.
• Desconecte todas las conexiones de entrar en el Mac, excepto para el cable de alimentación.
• Una vez que todas las conexiones se han desconectado, quite el cable de alimentación de la Mac.
• Espere 20 segundos.
• Vuelva a conectar el teclado, el ratón y el cable de alimentación en el equipo.
• Presione el botón de encendido para reiniciar el equipo Mac.
Espero que esto haya ayudado a resolver el problema de la línea blanca.
buenas noches. tengo un problema con mi proyector.. hace unos minutos encendio y se veia la imagen pero luego lo desconectaron y cuando volvi a encender solo prende la luz de power pero no sale la imagen quen podra ser???
Si el sistema se ve durante unos segundos esto quire decir que no es la pantalla, ma la ordenadora que se bloquea. Si la computadora ni siquiera empieza a cargar Windows entonces es un problema de hardware, RAM, perifericos, tarjeta de video, disco duro, o motherboard. Si empieza acargando windows y se apaga, entonces tiene que volver a instalar Windows.
Hola,
Tu pantalla tiene 2 sintonizadores, por que no intercambias tu antena y pruebas si de misma forma la falla se sigue comportando, o por lo menos cambia... ejem: que ahora falle el recuadro mientras que el principal ya no. De ser asi, acorralamos en mucho la falla en el sintonizador ya que un sintonizador es primario y el otro es secundario para funcion recuadro.
Prueba y me dices aprovecha, en este momento tengo una identica a la tuya en servicio!!!!
Si resuelves el problema, no olvides calificar mi asistencia
