Just replaced oven sensor..
SOURCE: the oven won't work, the
Hello Kevin,
Please replace the coil of the oven
Also call any oven specialist to inspect the coil.
Doing yourself may damage more, also whch may cost more.
SOURCE: Gas oven won't light and the broiler won't light
Hello, welcome to FixYa.
I've read your previous post's and can see a couple of scenarios have been thrown out there, so this may just add fuel to the fire...no pun intended.
It sounds to me like a tripped hi-limit safety thermostat is the culprit, hence neither ignitor so much as glows. I'll explain. If the valve where faulty the ignitors woul;d still glow as it is the ignitors which allow the valves to open not the other way around.
Further to that, if the ignitor where faulty, it is unlikely it would be both at the same time, however if a hi-limit safety tripped it shuts down power to both the broil and bake ignitors thus no oven function at all...that is it's function "safety".
The hi-limit safety on your range is on the back wall so you need to slide the oven out (if you haven't done so by now) to inspect it. To do so is pretty easy, one of two ways.
You can jump across it to see if it allows the oven to operate or you can ohm it out with a meter. it should simply be a closed circuit if good, open if not. It is the non-reset type unfortunately so you'll need to replace it.
example
It is part number 8300802 and available at "repairclinic.com" or "searspartsdirect.com" to name just a couple.
Let me know what you find and I'll be glad to help you moving forward from there. Good luck.
Regards,
Macmarkus :)
SOURCE: Model: JDS8850AAS -- Oven won't preheat above 150
The problem beleive it or not is that the bake ignitor is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake ignitor(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of ignitor make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake ignitor. I know it seems improbable that if the ignotor comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the ignitor comes on yet the oven won't heat that a weak ignitor is the cause 100% of the time
Hope this helps
Gene
SOURCE: Whirlpool Range model RF386PXGQ2 broiler won't shut off
Hi.
If the element does not turn off, possible faults are:
Shorted temperature probe.
Test temperature probe reading impedance. If impedance is zero or lower than 0.500 Ohms, the the probe is shorted. A good probe reads about 1KOhms.
Contact at element. A contact in element wiring harness may cause the element to stay on. Do continuity test between ground and element and on wiring harness.
Defective control module.
If problem is none of the above, then it is the oven electronic control(ERC). The ERC can be tested reading voltages.
Testing must be done by a trained technician.
