Ruby, try pressing and holding on button or you will have to reset.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Seems like you may have purchased the incorrect battery or they shipped you one that is NOT for your unit, if you purchased an "aftermarket" battery this could be the issue. Not saying aftermarket parts are bad, they are just massed produced and sometimes you get a bad one. Return it for refund or replacement. Try E-Bay for a reseller for this product, much less cost.
the battery wont stay charged? if youre putting in a fully charged battery and your car runs, but then the battery slowly dies, the problem will be your alternator. the alternator is what maintains a car batteries charge. try replacing the alternator. hope this helps.
well if it won't charge then it could be the batteries are too low for the charger to pick up or the charger is not working. If you have a voltmeter set it on 200 vdcand plug it into the 2 outter holes of the charger port located under the front of the joystick. Without the charger plugged in you will read the battery voltage and it should read 25-27 volts fully charged Now plug in the charger and the meter will be reading the charge voltage and it shoud be 27-30 volts. If you are reading 27-30 volts with the charger plugged in then the charger is working Hope this helps you
That means that the headset is already fully charged! Whenever you have a fully charged item and you plug it back in, the light will only stay on for a few seconds, signifying it's charged.
Make sure that the kindle is fully charged. Plug your kindle into the wall charger, a yellow light will light up. When the yellow light turns green, your kindle is fully charged. Then try turning on your device.
If the device still doesn't respond, do a hard reset by holding the power switch for 15 seconds
either a bad battery, or charge port. even if the battery was fully charged it will still keep the light on, try this. plug it in, and power it on, then remove the battery completly, the computer should stay on, as its running off the plug power cord. if this port is a bad one the pc will shut off immeadatly. and if it stays running then it will be the battery.
Try to perfrom power drain. You must first turn off the computer. Take out the battery and unplug the power adapter. Press and hold the power button for 30 secs. Put the batter back in, plug in the power adapter and power ip the computer then observe.
If you have a 400 series Roomba, try removing the battery, then holding down the power button for ten seconds, then recharging the unit before you run it again.
If you have a 500 series Roomba, don't take out the battery-- just press and hold the "spot" and "dock" buttons for about fifteen seconds. The Roomba will play a tune, and you can then charge it and try running it again later.
