Put a Phenom 1095 6 core in mine and it worked Upgraded the PS just in case. Now seem to have a BIOS problem though probably unrelated. If you google acer m3400 data sheet you can find the specs.
Yes the mainboard should be able to support an AMD AM3 CPU, however the mainboard will not be able to make as good use out of the CPU as an AM3 mainboard would.
AM2+ will use DDR2 800MHz RAM whereas AM3 uses DDR3 1333MHz or higher for example.
It's specification tells us that it is supported as it is labeled AM2+ the + stands for AM3 CPU's as well.
no, this board is only compatible with AMD Opteron 1000 Series AM2/AM3 Cpu's. This board is designed for a server environment, hence the use of the Opteron CPU which is primarily used for server systems. Your CPU is an Athlon series which is mainly for home/business use and will not work with this board.
You have a socket 754 motherboard. That socket had been in use for just 2 years over 5 years ago. Obsolete.
Get a new AM3 socket one and a new processor.
