Connecting to onkyo amp
SOURCE: sr7200 LFE (sub woofer) output stopped working
Chances are if The Receiver only has sound in Stereo Direct Mode and all surround modes and Sub out are Inop the DSP (Digital Signal Processing) Card is most likey defective. These boards are not available from marantz (D&M Holdings) and must be Component level repaired which usually is not cheap. If Only the Sub out is not working check setup to be sure sub woofer is set for on. Also If On Screen setup menu does not appear on video monitor Unit may need to be Reset manually which entails discharging a Capaitor on main P.C.B Contact [email protected] for details
SOURCE: Connecting a sub-woofer to Pioneer VSX-453 surround reciever
I got the same issue. But, I go ahead hooked it up two banana plugs on teh VCR outlet. It works fine on my Cerwin Vega Sub.
SOURCE: How can I connect my Onkyo TX-SR507 to a PC to play MP3 files
The easiest way is to use a 1/8" stereo to dual RCA cord and connect the output of the sound card to an AUX input on the receiver. These cables are readily available and cheap. You shoul dhave 3 mini jacks on the back of the computer related to the sound card setup.
1) Audio input mic
2) Audio input line
3) Audio output line
Connect the receiver to the audio output line jack.
Dan
SOURCE: How do I hook up a non powered sub woofer on my htr-5630?
You will need an amplifier or 2 channel receiver. Hook the sub out rca jack to the rca inputs on this new amp or receiver and hook the speaker terminals on sub to speaker terminals on same amp or receiver. Your Yamaha receiver doesn't have any power for a passive sub.Just pick up any old fairly high powered receiver for fifty dollars and you're good to go.I use old dolby pro logic receivers as they are a dime a dozen today. Good luck.
SOURCE: no video when connecting wii to Onkyo TX-sr507 AUX
Did resolve the issue? I 'm pkanning to buy wii @ my home. Please suggest me.
I do use the Onkyo 507.
