Philips Magnavox DVD/VCR Dual Player Logo
Les Johnson Posted on Mar 07, 2016
How can I finalize DVD for playback on other players?
Do i have to add a name to disc
5 Related Answers
Anonymous
  • 48 Answers
  • Posted on Jul 14, 2007
SOURCE: Won't play DVD+Rs
By mentioning that your disks are finalized, I am thinking that you are not creating the DVD in the proper manner. For DVD's to play back on commercial equipment, they have to either be authored, created from a ISO file, or cloned, bypassing the copy protection imbedded in many titles. Do a Google search on DVD authoring or cloning to learn how to sucessfuly create DVD's that will play back on your home player.
Anonymous
  • 244 Answers
  • Posted on Nov 24, 2007
SOURCE: UUURRRG
Not spinning disc
If it spins with a little help from yourself replace the spindle motor with improved motor, part number: RXQ0749A
Unable to detect discs
The laser head was the culprit. Replacing it fixed the problem. (Laser head code GRP6278A)
Difficulty reading cd, if it does read the sound is strange and sticks
Replace C101 (1000uF/16v)
Anonymous
  • 4 Answers
  • Posted on Jan 28, 2008
SOURCE: recorded disc playback trouble
You have to finalize the dvd's through the menu... from page 36 of the manual....on the remote control press SETUP use the arrow key to select "DISC EDIT" press OK Use the arrow key to select FINALIZE press OK. A confirmation window appears, use the arrow to select YES and press OK.
Anonymous
  • Posted on Sep 04, 2008
SOURCE: magnavox dv200mw8 disc error
I have the same problem, sometimes it works sometimes does, i have tested dvd always work on other dvd player, i am not happy with magnavox. ron
sesfc
  • 5 Answers
  • Posted on Dec 02, 2008
SOURCE: the magnavox zc320mw8 will not
Try this. Insert DVD. Press SETUP button. Once DVD has loaded the DISK FINALIZE option will be available. You can then FINALIZE.
I tried to dub old vcr home movies to a dvd and I accomplished that but when I tried to play dvds on my computer or other player the dvd could not be read. What do I do?
Did you finalize the disc? Make sure that you left some space on the disc after dubbing the movies. The finalization adds data onto the disc.
To finalize, put the disc back in recorder. Press Setup on the remote. Use the up/down arrow keys to highlight Disc Edit and press OK. Highlight the Finalize option and press OK. Select Yes and press OK. Wait for the procedure to finish.
In the future when you record, you may want to use the Auto-Finalize option. For more information, look at the manual. The finalize and auto-finalize steps start at page 44. The manual is available here: http://download.p4c.philips.com/files/z/zv427mg9_f7/zv427mg9_f7_dfu_aen.pdf .
If you did finalize the disc, then check that your computer has DVD-playing software. Starting with Windows 8, Microsoft stopped offering the Windows Media Center by default. You could purchase a DVD playback app from the Microsoft store. Alternatively, there are third-party DVD playback programs. VLC is free, https://www.videolan.org/ . Others, including Cyberlink PowerDVD, cost money.
Some DVD players do not read all discs. Some only read DVD-R (DVD-RW) even after the disc is finalized.
I hope this helps.
RECORDED DISCS NOT PLAYING BACK ON OTHER DEVICES
Did you finalize the disc on the DVD recorder that burned the file? Without more information on your DVD recorder, I can't give you exact directions to find the command on your unit. On my DVD/VCR, after recording, I usually finalize a disc before removing it from the recorder. On mine, I press Menu and go to Disc. I add a title (optional) and then select the Finalize option. Then accept the finalization (which makes it impossible to add more to the disc). For -RW discs, you can unfinalize and then reformat them. Write once discs are permanently stored.
What type of disc did you record to? Some other players may not recognize DVD+R or DVD-R discs or DL discs. Check the specs on the other players and try different brands/types of discs for future recording.
If you add a comment with the type of DVD recorder used to burn the problem discs, I may be able to give additional advice.
How can i get mini dvd to play on dvd player
Make sure that MiniDVD has been finalized in camcorder then it can be playback in any other DVD Player.
Finalize option would be available in camcorder dvd setup menu, select it to finalize recorded mini dvd disc, please note UnFinalized mini dvd disc will only playback in camcorder because of its raw data and Finalization will validate this raw data so other dvd players will recognize this mini dvd disc for playback.
Hope these info will help you.
Thanks.
3answers
MY DVD R DISC WILL NOT PAY IN MY DVD PLAYER - I HAVE A SONY DVD CAMCORDER BUT THE DISC WILL NOT PLAY ON MY DVD PLAYER
Please finalize recorded dvd disc in camcorder then it can be playback in any other dvd player.
Disc finalize option is available in camcorder disc menu.
Thanks.
7helpful
3answers
The magnavox zc320mw8 will not finalize a dvd for playback on anther dvd player
VHS to DVD playback
The document for the XBR716 needs to be re-written and re-issued, because it is missing information on how to finalize the DVD.
Solution:
Press the HOME button, then go to Disc Manager.
Select the Finalize menu, Finalize and OK to start.
Record on DC210 and playback on home DVD
You should absolutely be able to play the recorded DVDs from your camcorder in your DVD player, as long as you remember to finalize the disc and the disc is compatible with the player. If your DVD player is less than five years old or so, you should be fine, provided you're not using dual-layer discs.
5helpful
Accurian DVD Recorder/Hi-Fi VCR combo
You need to finalize the disc u recorded in order to play on other dvd's. press setup, press disc, press finalize then press yes. Finalization will start, this may take some time depending on the amount to be finalized. Be patient. Good luck.
P.S If u have the manual those steps are on page's 36-37.
1helpful
Can I playback my recorded DVD-R discs on any DVD Player?
Yes, A finalized DVD-R disc provides playback capability to most home DVD players and DVD drives. (An 8cm DVD-R disc recorded by this camcorder may not be able to be played back by some DVD players / DVD drives, depending on the player, the DVD-R disc and the condition of the recording.)
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
