Music Logo
Ryan Ashley Posted on Mar 06, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My peavey amp turns on but no sound when I plugged my guitar in. Thoughts?
  • Ryan Ashley
    Ryan Ashley Mar 07, 2016
    It says express 112. Transtube technology. The fuse is good I checked it. The model number on the speaker is 1236
David Payne
Level 3:
Top Expert:
  • Peavey Master 14,162 Answers
  • Posted on Mar 08, 2016
David Payne
Peavey Master
Level 3:
Top Expert:
Answers
14162
Questions
0
Helped
2998784
Points
455836
rhodesworks
Level 3:
Top Expert:
  • Peavey Master 3,159 Answers
rhodesworks
Peavey Master
Level 3:
Top Expert:
Answers
3159
Questions
Helped
562721
Points
331463
Contact Peavey customer support at this link-
Peavey com
Marcus barnette
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 07, 2016
Marcus barnette
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2706
Points
What model peavey amp? Solid state or tube amp? Does it have a fuse in it?
2answers
My peavey valveking 212 feeds back when the gain button is pushed it makes a loud whistling sound with nothing plugged in
Turn your guitar away from the amp's speakers. The pickups on the guitar are feeding the amp's signal back into the amp creating a feedback loop, especially with the gain button on. Loud volumes cause this looping path between the amp speakers and guitar pickups. You may need to reduce amp volume also.
Peavey problems
Numerous possible issues with your description. I would start with the tubes, and check if not one or more has faulted.
Peavey 6505 plus buzz...even when all controls on zero and no guitar plugged in
Sounds like a bad power supply filter cap...the buzz you're hearing is the 60 cycles hum that filter caps reduce or (hopefully) eliminate altogether. It may also be related to the tubes but finding the bad one will require some work. Any friends have this same amp? If so, try swapping one tube at a time and see if you get lucky. If this amp is new take it back ASAP as it is a manufacturing defect.
My peavy amp will not turn on
1- check the outlet for power by plugging in a lamp or something
2- check the amps fuse. Most power amps have user replaceable glass fuses.
How to fix a gt5 peavey rockmaster amplifier
Hi. My name is Danielle and I have a peavey rockmaster GT-5 guitar mini amp, and it can work with/without the cable. I lost the cable and I didn't need to worry because the amp still worked as long as it had good batteries. But, after about 4 months of no use of it, I put in a brand new battery and the light wouldn't turn on. I looked all over the amp to see if something was missing but I found nothing. I'm really not sure what to do because this is a very good amp and I'd hate to throw it away. Can anyone Help Me?
I have a Peavey MAX 112 Bass Combo amp. When I turn on the amp and have it plugged into the cord and bass, it immediately begins emitting a "whump whump" sound similar to the sound a beating...
The amp is doing what is called "motorboating". This is usually caused when the voltages to sensitive preamp stages are inadequately filtered or regulated and the sudden load of the output stages cause a dip in the voltages sent to the preamps which in turn vary the input to the output stages starting the cycle over. This will require electronic troubleshooting and if your not skilled in that, then it is NOT a DIY fix. What you are seeing is NOT normal, there is a defect.
No sound
You would NOT use a stereo cable to plug in your guitar.
The stereo cable would carry the battery voltage back to the amp and MAYBE cause the fuse to blow.
You use a MONO instrument cable for your guitar.
The ring connection is use to complete the circuit to turn on the battery in most guitars.
Replace the fuse ONCE and get the proper instrument cable (NOT consumer audio cable) for your guitar.
If fuse blows again, take amp to shop for service.
My amp and cable are working... but my guitar wont make sound... when i turn up the amp it makes white noise... HELP!!!
PLUG YOUR LEAD INTO AMP TURN UP JUST A LITTLE SEE IF IT BUZZES WHEN YOU TOUCH THE END OF YOUR CABLE.IF IT BUZZES THEN THE FAULT IS IN YOUR GUITAR MOST LIKELY THE ACTIVE WIRE HAS COME OFF THE INTERNAL GUITAR PLUG.
Top Peavey Music Experts
NOEL
NOEL
Ngoro
Are you a Peavey Music Expert? Answer questions, earn points and help others
