Question about American Standard Home
American standard single handle shower vavle drips when tub spout is on.
I installed new american standard single handle shower faucet. Water comes out shower head when tub is being used.
    New Friend:
  • 21 Answers
Be sure to pull the plunger all the way up when diverting the water between the the tub and shower if ti keeps giving you a problem it's faulty
Posted on Oct 19, 2016
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 226 Answers
SOURCE: water leaks from shower head while bath faucet is running
sometimes there are orings or gaskets that get tore in assembly one of those may be bad,or if it is around the threds you might try wraping teflon tape around the thred once or twice.hope this helps
Posted on Jun 14, 2009
Anonymous
  • 21 Answers
SOURCE: single handle tub faucet will not divert to shower
the diverter on the tub spout is bad you need to replace the tub spout or the pull up diverter if its a separate piece if you have the owners manual with a parts diagram you can order it on line from the manufacturer or a plumbing supply store. you will need to unscrew the tub spoup from the wall to do this use a broom handle or something similar inserted inside the spout and turn it to the left to remove it from the wall
Posted on Dec 03, 2009
EMSRSERVICEG
Lawrence Walters
  • 426 Answers
SOURCE: I just installed a single handle moen tub faucet
sound.s like repipeing
Posted on Dec 15, 2010
Why is water coming from shower head and faucet at same time?
sounds like you need a new tub spout with diverter...thats your problem...unscrew spout and go to lowes and match up with new one...use pipe dope on threads and reinstall new one...good luck
May 30, 2012 | Danze & Single Handle Tub And Shower...
No hot water pressure
These types faucets have a what is called an anti scald valve build into them, it is required by law, it is either defective or out of adjustment, contact a local hardware store for more detailed info.
Feb 02, 2012 | American Standard Plumbing
Water will not flow through on american standard with pressure balance. Some hot water came out with low pressure then stopped and now nothing will flow.
I just spent a week wrestling with a similar problem, and I'm posting in an attempt to save someone else an ulcer. Using a Colony single-handle valve, the temperature got so we couldn't control it. Either all hot or all cold. I called A.S. and they sent a new pressure balancing cartridge and new valve cartridge. Replaced both and then there was no water at all coming out of the shower head. Tried every possible combination of old and new parts, flushed pipes, etc. Finally took the shower head off and found it completely clogged with debris. It was a mix of sediment and the white grease that was in the new cartridges, which must have been displaced when I started messing with it. And it clogged it all at once (no flow problems before all of this). Works fine now!
Jan 02, 2011 | American Standard One Handle Shower Only...
Delta T13090 faucet shower head working at the same time.
The only possible explaination is that the water is finding it easier to go up than down. Water is lazy, just like me. ;)
Use an allen key to remove the tub spout. It's underneath and awkward. Once the allen key is loose, the spout just slides off. Try running the water. This may solve your problem and all you'll need is a new tub spout. If not.....
Turn the water off to the house.
Use an allen key to remove the handle.
Use a phillips to remove the trim plate (2 screws). Cut the silicone around the trim if it's there (which, in a proper installation it shouldn't be, but...)
Unscrew the nut (usually chrome) holding the cartridge into the brass body of the valve. The cartridge pulls straight out. Check for restriction in the ports of the cartridge itself. Check for restriction in the line going down to the tub spout. If you can't find anything, replace the cartridge.
Reassemble & Enjoy!
Aug 05, 2009 | Delta & Single Handle Shower Faucet
Delta 134900 handle Water coming out faucet and shower both
well the Diverter is not working it dose not matter the distance. when applied it should shoot the water to shower or tub if not working will come both.
Jun 15, 2009 | Delta & Single Handle Shower Faucet
American Standard Cadet 2-handle tub & shower set-Model#3275 - low pressure output
When you installed the new tub faucet you probably turned off the water to that faucet of even the whole house. IF IT IS AN OLDER HOUSE, TURNING THE WATER OFF AND BACK ON CAN LOOSEN SOME DEBRIS IN THE WATER LINES THAT CAN FIND THEIR WAY TO YOUR NEW FAUCET. If there is a screen at the end of the water outlet it can be clogged with gunk. Uncrew the screen on the water outlet and clean. You may also want to flush out the hot and cold outlets by turning the water off, removing the cartigages and slowly let water flush them out. Then reassemble. Also when you have the tub handles out you can turn the hot and cold supply valves off and on a few times to loosen more debris if it exsists........Joe
Oct 24, 2008 | American Standard Colony 3275.505 099...
Home Logo
343 people viewed this question
Top American Standard Home Experts
US Parts Center
US Parts Center
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
