Manikandan Posted on Mar 04, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have Sony vpl-ed3 projector if I press power button it is blinking green light it is no turning on it always blinking green light till the power off what is the reason for this please answer me
Electro Med Services
Level 3:
  • Sony Master 6,694 Answers
  • Posted on Mar 06, 2016
Sony Master
Level 3:
Answers
6694
Questions
Helped
1870149
Points
21433
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
5 Related Answers
Anonymous
  • 115 Answers
  • Posted on Mar 04, 2009
SOURCE: Sony VPL-CS5 menu will not display
Give input signal to the projector and see that if the menu appears or not on the screen.
if menu comes on the screen then put the backgroung color to blue, instaed of black.
if nothing comes on the screen, then the LCD panels are faulty.
Viren
RAVE SERVICES
Anonymous
  • 4234 Answers
  • Posted on Apr 09, 2009
SOURCE: Reset Timer Lamp Sony VPL-HS60 projector
According to the manual, you need access to the RESET button, the left and right arrows and the ENTER button to clear the counter. Press the following in order for less than 5 seconds each:
RESET
Left Arror
Right Arrow
ENTER
The above sequence should clear the counter.
Dan
projdoc
jasbo
  • 2239 Answers
  • Posted on Aug 04, 2009
SOURCE: power light blinking red
if the lamp goes out after the red led goes on, there is a fan issue and the projector is overheating or the ballast/power supply can't hold the voltage.
Anonymous
  • Posted on Feb 13, 2010
SOURCE: Sony BRAVIA VPL-AW15 LCD Projector power light
i have color bands running through the picture
Anonymous
  • Posted on Jul 15, 2012
SOURCE: Sony VPL EX-7 projector, it has been working well, now the lamp/cover blinks yellow and the switch on button remains red instead of green, it has refused to work, what do i do? Please help.
isert the lens cover properly
2helpful
How to reset sony projector vpl-es2 without remote control cause the panel key is lock?
Turn the projector on and leave in standby mode. To do this press the power on button for 10 seconds until the projector comes on.
To unlock the main panel keys, press the MENU button for 10 seconds.
6helpful
2answers
I have sony vpl ex7 and the power button keeps on blinking?
If it blinks with 2 flashes, it's overheated. Check the filter unit.
If it blinks with 4 flashes, a fan is not working properly. see if any fan is not turning on, and check why.
If it blinks with 6 flashes, it's a system internal failure.
1helpful
2answers
Sony VPL-CX61 lamp/cover blink. Power on, it
hi,
your projectors lamp cover may be open. or there is some thing happened (may be contact problem) with the lamp cover open sensing switch. just open the door and close it. and then try again.
ok
Sony VPL-DS100
I have solved this problem. Seems the rotating stand on the front bottom needed to be pushed and turned so that it inserts well inside. If it not well pushed the projector keeps shutting down itself every 10-15seconds. Took me about an hour to open the projector and doing all kinds of experiments to finally try that. :)
Sony vpl-px20
The bulb is faulty. Replace it.
Top Sony Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
