Question about American Standard Home
SOURCE: American Standard toilet constantly runs
The rubber cork thst lifts when you press the handle is leaking by and causes the water level to drop below shut off level so it trys to maintain the the shut off level every minute or so. Replace the cork with one made with the red rubber. good luck
Posted on Jun 20, 2009
SOURCE: hole in back of toilet (stool) leaks water.
The hole your refering to is common in the manufacturing of toilets and is generally filled before it leaves the manufacturing. I have repaired several toilets, new toilets, all American Standard, using a good grade of epoxy - not silicone. I used West System epoxy as this is made for marine projects and surprisingly states "toilet repair" as one of the uses of their product. I'd suggest carefully chipping the smooth porcelan around the hole to give the epoxy something to grip. Use a knife or screwdriver to gently chip the edges and make sure the area is dry. Press the epoxy into the hole and give it enough time to cure before putting it back in service. Of course, if the toilet is less than a month old I suggest returning it and getting a new toilet.
Posted on Jun 22, 2009
SOURCE: just installed a new American Standard Champion 4
the float is set too high
Posted on Nov 09, 2009
SOURCE: Toilets are refilling between flushes
Replace the flappers, and clean around the flapper seat.
Make sure the water level is 1/2 " below the large vertical tube by either bending the float rod down or adjust the skinny silver rod on a Fluidmaster unit.
Posted on Dec 12, 2009
SOURCE: commercial tankless toilet won't flush
There is a screw adjustment that basically allows so much water by then the valve shuts off. Located under the cover. If you already tried adjusting this then replace the diaphram. Plumbing shops will have the kits. Pretty simple to fix. Good Luck have a Great Day. Please give a 4 THUMBS UP if this free answer was helpful. THANKS
Posted on Apr 01, 2010
Sep 23, 2018 | American Standard Plumbing
Dec 13, 2012 | Water Heaters
Sep 16, 2011 | American Standard R120 Pressure-Balance...
Jul 02, 2017 | American Standard 2770.018w.020 Cadet...
Jun 06, 2010 | American Standard AMERICAN STD 100G NGAS...
May 08, 2010 | American Standard 2004.014 - Champion...
Dec 30, 2009 | American Standard Kitchen Faucet 6310 020...
Sep 09, 2009 | American Standard Toilet Tank ...
Jun 16, 2009 | American Standard Home
Dec 16, 2008 | American Standard 2748.328 Town Square 5'...
166 people viewed this question
