Impossible to answer your question as given. There are many possibilities for connecting your devices. Things you can't do:
Connect the speaker connections between units. This will likely fry both.
Connect the inputs between units. You won't hurt anything, but you also won't get anything.
If you tell us what you're trying to do, perhaps we can help. It will also help to know the make/model of your receivers.
SOURCE: How to Connect HDMI Components with AVR 3805 as Hub
In reference to the comment you added to our chat session:
Just connect your receiver to your TV using the same cable your receiver is currently using to connect to your TV, be it Composite, S-Video, or Component. Just switch your TV to that input when you need to set-up something on the receiver.
SOURCE: Denon AVR 2807 with Bose Acoustimass 15
Well,i can tell you are not very focus,cause you posted Denon AVR-2807 with Bose AC 15 problem,but under your details,you put down AVR-5807!
First of all,it is so unfortunate that you are NOT able to gain and experience to true ability in sound for this wonderful receiver when you are using a dual tweeters speakers and expect to have good sound separation as a TWO WAY speakers(a tweeter and a midrange-for true high frequency and mid frequency sound separation.)
Secondly,you have defeated the audio configuration of the Denon AVR-2807,since all your speakers are control BY the Bose subwoofer.
Now,i could show you a way to hook this up,and it doesn't matter how you connect them, they are the "bicycle tires" installed with a "Porche"engine if you know what i mean.
If you want a good recommendation for your "beast",i will more than happy to show you the way!
Cheers,
solutiondoct
SOURCE: how to connect 6.1 speakers to 7.1 receiver
Using the Onkyo display setup, you can turn off one surround speaker, and your receiver should realize it's using the 6.1 channels instead of the 7.1
If you don't want to go that route, use the mic setup that came in the box and your Onkyo will determine by itself the 6.1 channel layout.
It should work fine.
SOURCE: hooking up an external audio source (IPOD) to the Denon AVR 3803
sure
just get a cable with phono plugs to mini phone connector Radio shack has them
Connect teh mini phone to teh earphone jack adn teh phono plugs to the aux inputs
select aux and enjoy
SOURCE: problem with pioneer vsx-916 av receiver
i have been using this with two speakers and was working perfectly fine . recently i bought two floor standing speakers and worked fine when connected . When i tried connecting all four speakers it showed overload kindly tell me how this could be solved
First some background.
The use of 901's Active EQ (or any external processor) in any digital AV receiver setup for anything EXCEPT STEREO listening through the 901's alone requires you to have a separate amplifier for them and to avoid having to use a Tape Monitor which could introduce proprietary and potentially damaging Active Equalization back into anything in the AV Receiver with its conventional speakers.
Get yourself a nice separate amp, draw the Front L&R pre-out signals from wherever you can find them, in your case maybe the CDR or DVR/VCR outputs. On many AVR's, there is a pre-amp out for every channel in case you want to run external amps for any channels. That is how my old Pioneer VSX-36TX is equipped. For others (yours), you have to borrow the signals from a typical CDR or DVR/VCR Output RCA pair. Just remember, AV receivers disable digital inputs as soon as you switch in a Tape Monitor, so choose one you won
In an AVR, if you activate any Tape Monitor circuit at all, you will kill any digital sources. That is a function of AV receivers in general, nothing to do with 901's. Your Pre-Outs get us around that possibility and limitation but it also means you need a moderately powerful amp for your 901's.
http://www.retrevo.com/support/Pioneer-VSX-520-K-Receivers-manual/id/23653ag911/t/2/
This works for all models of AV receivers when you want 901's as Front L&R speakers...
I have a setup similar to what I think you're trying to do and it works great!
You're in luck because you have a full complement of pre-outs. You'll need a separate amp for the 901's.
The use of 901's Active EQ (or any external proxcessor) in any digital AV receiver setup for anything EXCEPT STEREO listening through the 901's alone requires you to have a separate amplifier for them and to avoid having to use a Tape Monitor which could introduce proprietary and potentially damaging Active Equalization back into anything in the AV Receiver with its conventional speakers.
In an AVR, if you activate any Tape Monitor circuit at all, you will kill any digital sources. That is a function of AV receivers in general, nothing to do with 901's. Your Pre-Outs get us around that possibility and limitation but it also means you need a moderately powerful amp for your 901's. I use a Carver MT-200.
Run it with the Active EQ between the receiver Front L and R Pre-Outputs ** and the 901's amp channels. ** Front Pre Out (or one of your analog Tape Outs) >>> Bose EQ Amplifer IN, then Bose EQ Amplier OUT >>> new amplifier IN.
Then set the new amp's volume control (if it has one, mine doesn't) to something HIGH and leave it alone. Run through your speaker setup routines on the AVR. After levels and distances are set the AVR will be the boss of the 901's. With 901's don't even need subwoofers but they don't hurt. If you do have subs I recommend sharing the LFE with the 901's.
I've done this in my own setup once. Turn the 901's around so the rear faces point into the listening area. Crank up a movie like Master and Commander and when the waves are crashing or cannon are firing you WILL FEEL A BREEZE from them. Now THAT is multi-media!
I advise having the 901's share LFE with any subwoofers you might have.http://www.retrevo.com/support/Harman-Kardon-AVR-230-Receivers-manual/id/386bh145/t/2/
