Honeywell HE220A1019 Whole House Humidifier Humidifier Logo
Posted on Nov 18, 2007
Water not running through humidifer
I have a honeywell he220 that worked great last season. This season the water will not run through it. The sail switch seems to be ok.Could it be the solenoid switch? How can I tell?
  • 5 more comments
  • Anonymous Nov 18, 2007
    Same problem.
  • timkiernan Nov 19, 2007
    I have the same problem. Pricing for the solenoid is more than half the cost of a new unit.
  • JPlacidi Nov 27, 2007
    I am having the same problem. I would change my filters religiously and this year when I went to turn on the humidifier , the water would not run thru it, why?
    How do I check to see if the solenoid is working?
  • Anonymous Nov 28, 2007
    I have the same exact problem. I had the unit installed last year and it worked great. This year...I turn it on and no water will pass through the solenoid valve. The saddle valve works just fine, but it appears the solenoid valve is shot. Wow...I've only used it about 4months.
  • author Dec 03, 2007
    Thanks so much for the tip. Cleaning the needle hole did the trick and the unit works great!
  • amtur Nov 17, 2008
    I too have the same problem every year. When the repairman fixes it they do not charge much. I am not home when they are here so do not get the oppty to ask what to do when I restart. It must be a simple solution
  • humd Nov 27, 2008
    Does anyone know how to clean the needle hole? I am not able to unscrew the water pipe inlet side!
JPlacidi
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 02, 2007
JPlacidi
Contributor
Level 1:
Answers
Questions
0
Helped
864
Points
0
I will try cleaning out the intake side of the solenoid
I will let you know the outcome
A
Anonymous
Mine had the same problem no water through the solenoid. It turned out to be the little adapter with the needle hole on it, attached to the solenoid on the intake side. It was clogged, cleaned it out and works great now.
He360 fan and water run continuously
Check yor wiring, make sure you have sail or pressure switch wired in series with humidistat to humidifiers 24V power. Pressure or sail switch will disconnect humidifier when furnace fan is off. Humidifier (110V) could be connected to any closest electrical outlet.
Wire Honeywell HE220 to N8MPN/L, *8MPN/L furnace control board
HI
I have similar isssue with HE220 but in my case the water run through all ththe time, even when unplugged from the power outlet.
Would that be solenoid issue?
the unit run fine for last season so the wiring is fine.
Any ideas would be greatly appreciated.
I hooked the humidifer up and water keeps running it dose not stop when furnace stops. What might be wrong?
Hello, this could be tw o different things. when you install a humidifier you need a means of turning it on and off with the furnaces blower motor, this is done by either a sail switch, current sensing relay, or by the transformer being hooked up directly to the furnaces control board. if you do not have one of those three than the humidifier will run continuously untill u manually turn it off at the humidistat. If you have one of those three installed already than the solenoid valve is stuck and must be replaced.
2helpful
The water runs constantly, not just when the furnace turns on.
Do you have a sail switch or current sensing relay with this humidifier? In order for the humidifer to turn on and off u need either a sail switch that senses airfllow in the return air duct and will turn off the humidifier when the blower motor stop or a current sensing relay that senses current on the blower motors common wire. I will post of pic of each one
INSTALLED HE360A, FAN MOTOR RUNS, EVEN WHEN FURNACE IS OFF? IS THIS NORMAL
Yes - but it doesn't have to work that way. There are several methods you can use to have the humidifier run only when the furnace runs. Look on the back page of the installation instructions. The method I chose was to install a sail switch. This is a switch with a arm attached which has a "sail' attached to it. When the furnace blower runs, the sail catches the blower airflow and activates the switch; allowing the humidifier to operate.
You can also wire in a current sensing relay (figure 6 on the instructions) or connect the humidifier directly into the furnace motor ignition box (if so equipped. My furnace dates to the late 70's and has no place to plug in a humidifier; which is why I installed a sail switch.)
Now however I probably would go with the current sensing relay option as this looks to be the easiest route to follow. Honeywell has their 32001754-001 avaliable for less than $35 from Sears.
1helpful
2answers
I just finished hooking up my new he 220a HUMIDIFIER
I have a HE220, HE 260 humidifier..by pass, flow thru. There is no water flow between the hot water tank and the humidifer. The water valve is on. Is there an inexpensive part I can replace myself first before calling a plumbing contractor?
2answers
My HE260A is discharging too much water
these are flow thru models and a lot of water passes thru them. The instructions say to not limit the water by closing valve at all!
1helpful
3answers
Too much water running through to humidifier
With the Honeywell he220, you will use alot of water, trying to turn down the water will only reduce your amount of humidity in the home, you may be able to adjust it a little but you need to take the cover off and reduce the water flow a little at a time watching the water as it flows across the pad, you just have to make sure the humidifier pad is getting plenty of water across it, to little and you lose your humidification, hope that was helpful to ya, thanks for your question,
mr.grzz
Humidifier not working
Depending on the age, transformers do go bad. It will have a odor to it if it is burned out, I just checked and the doorbell transformer at home depot is sufficient to run the humidifer. Dont worry that it is 20VA instead of 10VA. The VA is just the load it can handle, the higher the number, the higher the load. The transformer at home depot is around $15 dollars. You will use the 2 outer of the 3 screw terminals for the low voltage. I hope the helps. Steve
Install HE220 HoneyWell , humidity not increasing in the house.
You can try installing the water line to your hot water if it is installed on cold line for more humidification. You should make sure your humidistat is up line 6" @least from humidifier for proper humidification measurement.
Top Honeywell Humidifiers Experts
Paul Carew
NOEL
NOEL
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
