HP LaserJet 4600dn Color Printer Logo
D
Dick Alberts Posted on Mar 02, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Failure code 57.40 - HP LaserJet 4600dn Color Printer
Eric
Level 2:
Scholar:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 162 Answers
  • Posted on May 01, 2016
 Eric
Expert
Level 2:
Scholar:
Cheetah:
Answers
162
Questions
0
Helped
40409
Points
319
First, turn the printer off. I'd go so far as to unplug it, wait a minute, and turn it on.
If that doesn't work, take it in for service. It could be as simple as a fan - or it could be the logic board controlling it. Neither tend to be user-serviceable, at least not easily.
6 beeps what dose it means
Dell beep codes:
If your computer beeps during start-up:
Run Dell Diagnostics to identify a more serious cause.
Beep Codes Your computer might emit a series of beeps during start-up if the monitor cannot display errors or problems. This series of beeps, called a beep code, identifies a problem. One possible beep code (code 1-3-1) consists of one beep, a burst of three beeps, and then one beep. This beep code tells you that the computer encountered a memory problem.
Contact Dell for technical assistance.
Code Cause 1-1-2 Microprocessor register failure 1-1-3 NVRAM read/write failure 1-1-4 ROM BIOS checksum failure 1-2-1 Programmable interval timer failure 1-2-2 DMA initialization failure 1-2-3 DMA page register read/write failure 1-3 Video Memory test failure 1-3-1 through 2-4-4 Memory not being properly identified or used 3-1-1 Slave DMA register failure 3-1-2 Master DMA register failure 3-1-3 Master interrupt mask register failure 3-1-4 Slave interrupt mask register failure 3-2-2 Interrupt vector loading failure 3-2-4 Keyboard Controller test failure 3-3-1 NVRAM power loss 3-3-2 Invalid NVRAM configuration 3-3-4 Video Memory test failure 3-4-1 Screen initialization failure 3-4-2 Screen retrace failure 3-4-3 Search for video ROM failure 4-2-1 No timer tick 4-2-2 Shutdown failure 4-2-3 Gate A20 failure 4-2-4 Unexpected interrupt in protected mode 4-3-1 Memory failure above address 0FFFFh 4-3-3 Timer-chip counter 2 failure 4-3-4 Time-of-day clock stopped 4-4-1 Serial or parallel port test failure 4-4-2 Failure to decompress code to shadowed memory 4-4-3 Math-coprocessor test failure 4-4-4 Cache test failure
1helpful
Dell inspiron m 5030 7 beep code
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
1helpful
How to fix? Dell mini inspiron 10. Its has a 8 beeps. Failure displays.
DELL BEEP CODES
1helpful
My machine beeps 2 long and 4 shot times. what is the problem?
DELL BEEP CODES
Dell studio 2 beeps
DELL BEEP CODES
7 beeps will not come on
DELL BEEP CODES
Dell inspiron beep codes
These are the Dell beep codes.
DELL BEEP CODES
2answers
When I turn on my dell 9200, a beeping sound starts from the CPU and nothing comes up on the screen
how many beeps you have?if three short beeps its you RAM failure..try to reinsert you RAM or replaced it a new RAM..if theres a long beep..its your video card..
Everytime i start up the computer it beeps 3-4 times, and the monitor says vga input not connected...whats could be the problem?
here are the beep codes for your exact dell model. this should give you a starting point on finding out what the problem is.
Reseating the memory modules may fix the beep code errors in the following table. If the problem persists, see "Contacting Dell" in your Owner's Manual for instructions on obtaining technical assistance.
Code
Cause
1-3-1 through 2-4-4
4-3-1
If you hear one of the following beep codes, see "Contacting Dell" in your Owner's Manual for instructions on obtaining technical assistance.
Code
Cause
1-1-2
1-1-3
NVRAM
1-1-4
1-2-1
1-2-2
1-2-3
3-1-1
3-1-2
3-1-3
3-1-4
3-2-2
3-2-4
Keyboard Controller Test failure
3-3-1
NVRAM power loss
3-3-2
NVRAM configuration
3-3-4
Video Memory Test failure
3-4-1
3-4-2
3-4-3
4-2-1
No time tick
4-2-2
Shutdown failure
4-2-3
Gate A20 failure
4-2-4
4-3-3
4-3-4
4-4-1
4-4-4
Cache test failure
2helpful
2answers
What does a AMI bios beep code of one long and 9 short
AMI BIOS beep codes Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep Code
Descriptions
1 short DRAM refresh failure 2 short Parity circuit failure 3 short Base 64K RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed
k24674
Grand Canyon Tech
Grand Canyon Tech
