Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC3220
just right click and save as on the download links.
if this does not work you can try the search method,
you do
this by either holding down the device button eg: TV or if you have one
the "magic" button for three seconds, a light should then flash twice
to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
SOURCE: Jumbo Universal Remote
does your remote have the code search button? if it does, just hold the device key (TV, VCR, etc) until it blinks. Then hit the code search button until the device turns off.
SOURCE: Universal Remote code for Cyberhome dvd
I have a Cyberhome remote control but no player, so I was about to bin the remote. Send me your address and I will post it to you. Email me at bus1& travers.net (replace & symbol with @ symbol).
SOURCE: dmtech remote control programming codes
I have been looking for the same codes myself and all I have found is:
0157
0159
0335
1994
2024
2031
0067
0312
0910
0208
0586
hope one of these work for you.
SOURCE: Trouble programming Universal Remote to a DTV Converter Box...
Not a complete solution, but, around the last page (pg. 14) of your converter box manual there are codes listed for universal remotes. I happen to have a Philips remote that is listed. My code to control my dtv box is 0354. It appears that they have all codes listed for all Radioshack model universal remotes. I would suggest getting a Radioshack remote for Your "Digital Stream" (Radioshack) dtv box...
