Panasonic KX-TGA430B Cordless Phone Logo
l
linda Posted on Mar 02, 2016
I was given this phone. Can't get voicemail because I don't know password, how do I find it
Dont know voicemail password
Are you referring to the voice mail on your cell? What company do you have service with? If using cell, you may be able to try dialing 611 and then press the send or call button. then select the option for reset password. (When you received the phone, were you able to put it in your name with your account info? If so, you may be able to provide answers to the security questions with your account to reset your password.) Let me know if this helps.
Voicemail
The D1660 isn't an answering machine or a voicemail system. Please refer to the instructions for whatever answering machine/voicemail system you have on your phone line.
If you require further assistance feel free to repost your question, but please specify the make and model of the answering machine/voicemail system.
Don't know password
feature 983
it will say log- press 1020000
it will say password-under that it says reset-push that soft key!! press release.
default will be 0000 once you access voicemail(981)
What my voicemail 4 digit passcodefor 2402620085
Your voicemail password is a 4 digit number that you enter when you want to listen to your voicemail messages from any other phone other than your mobile phone - this is called remote access. This voicemail password gives you the protection to know that only you can listen to your voicemails.
It is vital that your password is set to a random 4 digit password. To change your password, all you need to do is:
  1. Dial 173 from your mobile
  2. You will then be asked to pick a 4 digit number, and then press the # button
  3. If you are happy press press 2
Your password is all set up and you will be prompted to enter it whenever you want to listen to your voicemails through remote access.You will only need to use this password when accessing your voicemails from another phone. You will not need to use this password when accessing your voicemail from your own mobile phone - you simply dial 171 as normal
You can reset your voicemail pass code by dialing 611 or 1 800 331 0500
From the main menu, press3 (To get help with voicemail)
Press 2 to reset your voicemail pass word
Enter Billing Zip code
Customer will receive a text message to their wireless phone with their new voicemail password.
OR
You can log into your "My Account" from the www.cingular.com
From the My Phone page, click Reset Voice Mail Password.
Choose a wireless number from the dropdown menu and select Submit.
A text message is sent to the wireless phone with the new password.
Feb 24, 2012 • Cell Phones
How can I check the voicemail, my assistant left and I don't know how to retrieve?
Where did your assistant check the voicemail? In a TVA system, each extension VM password can be reset from mailbox 999. If you don't have that password, you would have to call your dealer/installer or check their notes. If you're trying to get to the General Delivery Mailbox, it's done from the Message Manager's mailbox (998). Again, it needs notes, but I think you can reset that password from MB 999.
Carl
Need to get into my voice mail but I don't have the password. It was someone else's phone before me and I don't know the password and I need to reset it. need help!
This happened to me once as well, when I first purchased my phone they forget to give me my temporary password. I was able to call my carrier and they simply told me my password. I would recommend that you do the same thing. Call your cellular provider and let them know your situation. You will need to have adequate information in order to prove that you are the new owner. When you purchased the phone why did you not change numbers and such. That would have made you the registered owner, giving you easy access to things like your voicemail password. Hope this helps, and good luck DJRYDR
Jul 27, 2011 • Cell Phones
2answers
How do i reset the password for voicemail on a Panasonic KX-T7735
The only way to reset the password if you don't know or remember the original is to call the provider. If you don't know the customer service number, you can always dial 611 from the mobile phone itself.
May 04, 2011 • Cell Phones
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
