Hi There
Here's some of them you can read to read. Hope this helps you.
F/11
Serial
Communication Error
Communication
between the Central Control Unit (CCU) and the Motor Control
Unit (MCU) cannot be sent correctly.
- Check
Wire Harness connectors to the MCU, the motor, and Central
Control Unit (CCU)
- Check
the Drive system for any worn or failed components
- Check
MCU
- Check
CCU
- Check
Motor
- Check
Wire Harness
F/dL
Door
Lock Error
A
Door Lock Error occurs if the door cannot be unlocked. It
will try to lock it 6 times before displaying the error.
- Door
Lock Mechanism broken or removed from the Door
- Check
Door Lock/Switch Assembly
- Check
the wire harness connections to the Door Lock/Switch Assembly
and Central Control Unit (CCU)
- Door
Lock/Switch Assembly Failure
F/02
Long
Drain
If
the drain time exceeds 8 minutes, the water valves are turned
off and "F/02" is flashed.
NOTE:
After 4 minutes the "Sud" error will be displayed,
then 4 minutes later the F02 error code will be displayed.
Press
PAUSE/CANCEL twice to clear the display.
- Check
the
drain hose and make sure it is not plugged or kinked.
- Check
the electrical connections at the pump and make sure the
pump is running.
- Check
the drain pump filter for foreign objects.
- If
the above does not correct the problem, replace the pump.
Take your time reading this i hope it helps you out.
Thank you for writing to fix ya.
Best regards Richard
