Olympus AS-2300 PC Transcription Kit Logo
Carol Lee Posted on Feb 28, 2016
Is there a driver i can download so my transcription kit including footpedal can be used. Normally it only works on Windows XP. Now i am using Ubunto 14.04
3 Related Answers
Anonymous
  • 928 Answers
  • Posted on Nov 16, 2008
SOURCE: Lost CD for Olympus AS-3000 Transcription kit, need to download
you can go to the link below and just follow the steps to get the right software.
http://www.olympus.co.uk/consumer/2590_software.cfm
tscmusa
Mitch Davis
  • 95 Answers
  • Posted on Apr 05, 2010
SOURCE: looking for instruction manual for using Olympus
this should work:
http://www.olympusamerica.com/files/oima_cckb/AS-2400_Instructions_EN.pdf
javer821
Javier Gonzalez
  • 207 Answers
  • Posted on Apr 22, 2010
SOURCE: Hi, my boss has purchased this DS5000 and we have
Hello the reason is You need the transcription kit you can find the kit at http://www.tvps.com/Products/Olympus-AS-5000-Digital-Transcription-Software-Kit---New__OL-AS-5000.aspx
How do I get help with my AS240 transcription kit, it won't work with my Windows 8 laptop
You probably need the driver for Windows 8. Check Olympus website for downloads or support for driver.
Problem with Olympus AS-2400 PC Transcription Kit
I saw the AS2400 is compatible with Windows XP/2000/Vista.
You can install Windows XP in your computer (I presume you have a 4th Gen Intel processor installed in it) and run this software under Windows XP.
On the Windows 8.1 Help and Support, search: Windows XP
1helpful
Need to have the drriver for unit Sony ICD-P520
Hello you can find a download on this transcription kit http://www.tvps.com/Products/SONY-FS-85USB-Transcription-Software-Kit---New-FS85USB__SO-FS85-USB.aspx on the bottom of the page is a link for the New SONY Digital Voice Editor 3.3.01 - includes drivers. Before downloading and installing the software, please check the system requirements: to determine whether or not this program is compatible with your computer.
Good Luck.
3answers
Olympus AS-2000 Dictation Kit - Foot switch doesn't work on Vista
HTML clipboard Olympus AS-2000 is not Vista compatible, you need to upgrade your software, I am not sure which version you have, but I think its version 6 ? You need to upgrade your software from version 6 to 7 (free) and then from version 7 to Standard (also free ) . check your foot pedal if it's RS-23 ( check the back of it ) then you need a new foot pedal ( RS-25 or RS-27 ) , if you have the RS-25 or RS27 you are ok .
http://www.olympusamerica.com/cpg_section/software_results.asp?id=1219&os=w
Hope this will help
Joseph
1helpful
Philips 9750 transcription
Just hit the download button to download. Then to upload, select the file or files in the software, and drag to the dpm at the lower left. The 9750 will need to be in the download mode by pushing download first.
I have a DSS Player 2002. I just bought a RS 27 Foot Control switch. I've plugged it into the port but can't seem to get it to activate. I've even taken my computer and the switch to a computer shop and...
the software does require a special software key in order for the footswitch to work. Also the footswitch must be plugged in before the software is installed. if this is the case...uninstall and reinstall the software with footpedal attached
Top Olympus Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Ngoro
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
