HP Photosmart C5280 Printer Logo
Kandee Hanzel Posted on Feb 28, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I hook up to be wireless printer.
Trying to print from iPad
Remco
Level 2:
  • Expert 67 Answers
  • Posted on Feb 28, 2016
Remco
Expert
Level 2:
Answers
67
Questions
0
Helped
80540
Points
309
Call On Given Number: 1-888-508-8524
Their Technical Expert may troubleshoot the issue Over The Phone.
Hope this may be helpful for you !!!
Photosmart c4280 up address
The IP address for the Photosmart C4280 printer can be found by following these steps:
  1. Press the Setup button on the printer.
  2. Select Network from the menu.
  3. Select Wireless Summary or IP Address, depending on your printer model.
  4. The IP address should be listed on this screen.
If you are trying to print from an iPhone or iPad using a USB cable, you will need to use the Apple AirPrint feature, as the device does not support USB printing. To use AirPrint, ensure that both the printer and the iOS device are connected to the same Wi-Fi network, and then select the printer when prompted during the print process.
Trying to print from my iPad, it was working now it won’t print
There must be a bad connection between the iPad an the wireless connection. Try setting up the printer again on the WiFi. Check where the printer plugs in to the wall. If it still won't print call your internet provider or support about it.
1helpful
2answers
How do I add my iPad to my printer?
Here is a solution to add the ipad to your printer.
Follow the below steps to add:
·You have checked the latest version of iOS on your iPad.
·You have to connect the iPad to the wireless network by using the network name and password.
·You have AirPrint enabled printer.
·Now days the Air Print is built into most of the popular printer models. To check if your wireless printer is supported, you can view the list of Air Print enabled printers on Apple's website.
·You have a printer is connected to the same network as your iOS device or Mac. Your iPad won't recognize your printer.
·After turning on your printer, wait a few moments before printing from iPad or iPhone. Some printers take a minute or two after powering up before joining your network.
·You have to setup printer on iPad correctly to open the printer's software on your computer and look for a check box saying "Enable AirPrint."
·You can only use AirPrint with iOS core programs, such as Safari, Mail, Pages, and Photos, you can be print items like emails, photos, documents and WebPages directly from your iPad.
·Click the action icon button located on the top bar of the program screen that looks like a rectangle with an arrow coming out.
· This button will open a menu options. Tap the 'Print' button from the choices that appear to load the 'Printer Options' screen.
·When you are printing from iPad for the first time, you need to hit select printer. Afterwards your iPad would scan for the local AirPrint printer.
·Select the numbers of copies you want to print and then tap the Print button to print the desired item.
    If you have still facing any issues to add my iPad to my printer call to this toll-free number +1-800-836-3987 or visit this website 123.hp.com/oj6830.
How do I print from my ipad to konicaminolta MC 1690 printer
You will have to set up wireless printing from your iPad, but also your printer has to be able to print wireless aswell
Connect wireless Epsom printer to ipad
As far as i know you can print from ipads only to airprint enabled printers. I think only HP has such printers. So having a wireless printer is not enough. However your computer can run an airprint software and the ipad could print to your printer connecting through that software. Of course this means that whenever you want to print from your ipad the computer should be running.
2helpful
How to connect iPad to wireless printer
what type printer do you have? you need a wireless router.
connect the printer to your wireless router via ethernet cable or wireless. after setup is done.connect the ipad to the same wireless router...navigate to printable material from the iPad, safari is easy just launch it.click the arrow in the top left corner of the iPad, print should be an option, click print.if you do not see you printers name thenyou should then see add printer, click itif the printer is setup correctly and is "air print" capable (wireless printing) you should see it as an available printer. its simple---- I wish this site did not suck so bad with uploading videos I would show you step for step.... more questions just ask
How can I connect my ipad to my Canon printer to print
Printers can be really complicated because it involves networking. The easiest way is to get a product like Lantronix xPrintServer.
xPrintServer enables wireless printing for iOS devices such as iPads and iPhones using their native print menu. It eliminates the need to print through apps, install software, or email yourself documents for printing. And more importantly, you don't need to buy a new printer because xPrintServer works with more than 4,000 top brand USB and network printers.
2answers
Hook up to iPad
You can connect the printer on Wireless to the iPad using third party Apps from Apple store.
For IOS 4, you can use native apple app "Airprint" to print directly through wireless.
Check this link to see compatible printers that support Airprint.
http://support.apple.com/kb/ht4356
Want my Apple iPad to be able to print (wirelessly) to my x2580 printer. Is there now software to allow it to print from this and/or other low-cost wireless printers? Vic Cook, [email protected], phone...
You just have to update your Ipad version so that you can print using your Ipad.
I would suggest to click_here so that you will be directed to the apple site support that will help you to update your Ipad.
1helpful
I have an ipad and bought a hp c310 wireless printer to allow me to print. It was working well until i upgraded my router to dir 825. now my ipad does not recognize my printer. Once i reset the new router...
As of right now printing from the iPad is only "officially supported" by like 4 types of HP printers. I am not sure if yours is one of them (it is the newer ones for now). There are some tricks you can use (extra programs to install) that should allow all printers. Do you have a mac or a PC? If you have a mac follow this guide and it should work for you....
http://www.wired.com/gadgetlab/2010/12/ipad-iphone/
If this was a help please give me 4 thumbs up as I am trying to build up my rep on this site!
k24674
Grand Canyon Tech
Grand Canyon Tech
