How do I fix a stuck analog clock on a kitchen range?
We just got an older Magic Chef range and it works fine except that the hour hand on the analog clock is stuck. Is there a way to get it unstuck and if so, how?
Start time should be set to current time of day (according to the clock on the stove) and the stop time should be set for at least two hours later. This will allow the timed oven feature to work for the self clean option. ***Keep in mind that if the clock does not work you will have to shut the oven off yourself after the two hours is up!!*** Good Luck!
Hi there Heres the codesfor you and hope this helps and let me know.
F1
Defective touch pad or clock (ERC)
Replace touch pad or clock (ERC). Touch pad is a more common problem.
Refer to F1 test at the top of this page for more information.
F7
Function key shorted or stuck
Replace touch pad or if touch pad is part of the clock, replace the clock
(ERC). Thank you for writing to fix ya. Best regards Richard
The error code F7 means that the Function key is shorted or stuck. TO fix this error, replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
F1
1.
Watchdog on board 2. Touch membrane defective
To determine
which component is at fault, disconnect ribbon strip. If
NO fault code, replace membrane, otherwise replace board
F2
Oven too hot
Check oven
temperature sensor
F3 F4
Open or shorted
oven temperature sensor
Replace
F5
Hardware and
watchdog circuits disagree
Replace clock
assembly (also called the ERC)
F6
Missing AC
signal
Replace clock
F7
Function key
shorted
Replace touch
pad
F8
Analog/Digital
converter
Replace clock
F9
Door latch
Check door
lock circuit
F10
Function key
stuck
Replace touch
pad
F1
1.
To determine
F2
Oven too hot
Check oven
temperature sensor
F3 F4
Open or shorted
Replace
F5
Hardware and
Replace clock
F6
Missing AC
signal
Replace clock
F7
Function key
shorted
Replace touch
pad
F8
Analog/Digital
converter
Replace clock
F9
Door latch
Check door
lock circuit
F10
Function key
stuck
Replace touch
pad
The F8 failure code description is an Analog / Digital problem. To resove this error code, please replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
