Question about Frigidaire Ovens
Frigidaire fgfl77ase takes to long to preheat then oven doesn't cook the food but inside does get hot...burners and broiler works...speed bake does not...what to do?
    Top Expert:
  • Frigidaire Master
  • 12,962 Answers
The bottom oven element is in need of replacement. Period.
Posted on Feb 26, 2016
6ya staff
SOURCE:
Carmen Mikulic
  • 415 Answers
SOURCE: maytag mgr5870 not baking correctly
hi there,
sounds like the TOD may be at fault. can you supply me with the model # on your stove please?
as far as the popping sound, that would the spark module.
Posted on Sep 14, 2008
Anonymous
SOURCE: Oven not working properly
I just solved this problem with my GE gas range. I waited forever for the oven to warm up. The igniter would glow, light the burner and burn for a minute or so and go out. It would repeat this process till oven reached operating temp, which took forever. Problem is in the igniter. It may be glowing, but it is not letting the gas valve stay open, because it is not hot enough to create resistance in it to keep gas valve open. I had replaced the thermostat thinking it was the problem. The good part about it was I could take it back because my buddy works at supply house. Once the igniter was replaced, the oven fired up and stayed lit till operating temp was reached. It will also hold the oven temp much better. Oh yea, the igniter will stay glowing while the burner is on. Hope this helps.
Posted on Nov 29, 2008
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Frigidaire gas oven - model FGF366AWA - doesn't get hot inside
Yes it could be the thermostat, but what you need to find out and it is difficult to do, is determine what is cutting your gas back off.
The thermostat could be doing that but the most likely cause is the ignitor.
http://www.appliancepartspros.com/part_details.aspx?part_id=2150412&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d111760%26diagram_id%3d335207
The amount of electric going through hte ignitor is what tells the gas valve to stay on. When the ignitor gets old it does not pull enough power anymore. The the burner lights for a bit and then cuts out before it should giving you some heat but not enough. It just sits there and cycles...
https://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
You can find parts for your unit by doing a search for “appliance parts”.
Once you get the results of the search, pick a site and when it comes up it will usually ask for the model number of your unit.
Enter your model number and you will then get a page with exploded views and a parts menu.
Find the part you need and then order it.
Check a few different sites to be sure that you are getting the best pricing.
Most sites can have the part to you in a couple of days.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Jan 01, 2010
Testimonial: "Tips were helpful and response was very quick."
TheMobilian
Dan Webster
  • 8220 Answers
SOURCE: Oven appears to start, takes forever to preheat,
This is what I would do: I would unplug the range and connect my test cord to your range cord. I use an ammeter along with my test cord to read the amp draw of the bake ignitor. If it cannot get above 3.5 amps I know the ignitor is bad or weak. Since the oven is working that means there is a good circuit. In order for the safety bi-metal to open the amp draw must reach 3.5 amps or better. So to me I am thinking bad ignitor. To get to it I remove the door oven racks and bottom, I then remove the flame spreader and unplug the quick connect to the ignitor. I remove the burner and ignitor and replace the ignitor on a work bench. I am too old to be bending over and trying to do any parts replacement inside an oven. LOL. I have a training film which shows how the silicone carbide ignitor works HERE. Post a model number and I may have a service manual, do not forget to rate the answer.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Feb 26, 2010
Testimonial: "This advise seems right on. Thanks for your fast and detailed advise. Steve"
Anonymous
SOURCE: model FEFL78CBC frigidaire oven bottom (bake)
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Posted on Mar 16, 2010
How to change lower element in DeLonghi Airstream Convectio Oven
  • How to change lower element in DeLonghi Airstream Convectio Oven??
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Oct 28, 2017 | DeLonghi Ovens
    Oven taking to long to preheat the doesnt cook the food...speed bake button not working...but broiler and burners do..this just started. IT WAS WORKING
    call in a technician or electrician
    could be thermostat or a blown element ( probably an element)
    Feb 25, 2016 | Ovens
    Oven burner and broiler burner don't warm at all. Stove top burners work. Clock display normal. When turned on lights indicate oven on and preheating (normal). I have reset the main circuit breaker with no...
    Hi Brian, thank you for your post!
    Sounds like the either both bake and broiler element may be faulty or a potential wiring failure to the elements. You may want to connect with a local servicer who will be best equipped to pinpoint the problem. If you don't know a qualified technician, you can use the service locator option on the manufacturer site to find one near you.
    Sep 15, 2013 | Frigidaire 30 in. Electric Gallery Series...
    GAS OVEN WILL NOT GET HOT
    see this instructions and fix it. God bless you
    1. eHow
    2. Home & Garden
    3. Home Appliances
    4. Other Home Appliances
    5. How to Troubleshoot a Gas Range Oven That Won't Heat
    By Kefa Olang, eHow Contributor
    Although gas range oven may prove useful for cooking and baking, they may fail to ignite if they aren't properly maintained and set up. Lighting a gas range often involves simply turning a knob; however, blockages from food particles and debris caught in the burners, improper burner cap installation and gas supply are common problems that interfere with your gas range oven's performance. A few troubleshooting guidelines may solve these problems safely.
    Other People Are Reading
    Things You'll Need
    • Toothpick
    • Paperclip
    Instructions
      • 1
        Check you have gas in your tank if your gas range oven won't heat. Contact your gas supplier if you've run out of gas.
      • 2
        Clean the burners if you have gas but your burners still won't ignite. To clean the burners, lift the burner caps 9b4f010f-be4f-4db6-8a88-4c3fd17e3339.gif
      • 3
        Inspect the small vertical holes on the side of your burners for dirt, food and debris. The gas won't ignite if they are clogged. Scrape dirt, debris and food from the vertical holes using a pointy object such as a toothpick or paperclip.
      • 4
        Reinstall the burner caps properly. If they are tilted or wobbly, the gas may not ignite. Install the caps on the right burners. Some burners are smaller than others, so match the caps to the appropriate burners.
      • 5
        Move the burner knob to the "Lite" position and wait for the gas to ignite. If it ignites, rotate the knob to your desired setting. If it doesn't ignite, contact a qualified appliance technician.
    Jul 18, 2013 | Ovens
    My gas oven (Frigidaire Gallery) is not preheating or coming up to temperature. The broiler and stove top burners work fine.
    Most probable cause is a weak bake burner ignitor,if you can remove the floor of the oven and see a orange glow but within one minute thier is no flame the ignitor that glows is weak and needs to be replaced,if no glow at all ,if your capable find the 2 wires to the bake ignitor,using a volt meter set to AC volts there should be 120vac to the ignitor. If their is 120 vac and absolutly no glow the ignitor is cracked and needs to be replaced,if their is not 120 vac it could be the gas safety valve or control
    Jul 18, 2011 | Frigidaire Ovens
    Frigidaire FES367ASE Slide in range
    Someone mis-wired the new control. Turn off the power to the range. Open the control console,switch the bake and broil wires on the oven control.
    Sep 22, 2009 | Frigidaire FEB27S5A Electric Single Oven
    Kenmore oven lower element sporadically heating.
    When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
    You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
    May 27, 2009 | Ovens
    Brand new Frigidaire FGB24S5A Gas wall oven not registering corre
    some units will need to be adjusted if you live in a high altitude above 3000ft.
    Dec 10, 2008 | Frigidaire FGB24S5A Gas Single Oven
    WHY WON'T MY OVEN HEAT UP?
    Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
    Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
    Ovens Logo
    103 people viewed this question
    Top Frigidaire Ovens Experts
    Marvin
    Marvin
    Bruce Denton
    Alan Chouinard
    Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
