Hitachi Split AC. Turn on the mains, the fan turns on for few second then the filter clean red LED starts blinking and AC goes dead. Only the power light is on and red LED is blinking (5 times & puase
Hitachi Split AC. Turn on the mains, the fan turns on for few second then the filter clean red LED starts blinking (five times & pause) and AC goes dead. Only the power light is on and red LED is blinking.No Response to remote control after the red LED starts blinking. Model : SPLIT AC - 0.9T CLASS HITACHI SAC KAZE - RAU010KQD
What could be the problem ?
Hitachi Split AC. Turn on the mains, the fan turns on for few second then the filter clean red LED starts blinking and AC goes dead. Only the power light is on and red LED is blinking.Hitachi Split AC. Turn on the mains, the fan turns on for few second then the filter clean red LED starts blinking and AC goes dead. Only the power light is on and red LED is blinking.
You can't post conmments that contain an email address.
Did you figure out why the ac wasn't responding to the remote? I am having the same problem. I just cleaned out the filters but it's still not responding to the remote. I have already tried reset button in the remote, which didn't help. I am pretty sure that the remote is not out of battery.
the red light turns on automatically after 120 hrs of running to remind us for cleaning the filters. once you cleaned the filters and inserted back , then just keep ac in stand by mode, open the remote panel and press the button on extreme right bottom of the remote ( see carefully in the remote, there is very light image of the filter is made along with the button). red light will go off. no need to press the reset button.... enjoy
it does sound like your lamp due to the led's. Check how many hours you have on the lamp. You should be able to do this in 2 minutes. Also check to see if you if you need to clean your filters.
Have you checked the filters? I have a Sanyo PLV-75 and had a similar problem. The normal fan would come on when the unit was first started, then after a few seconds the secondary fan came on and then the unit would shut down. Called tech support and they asked if I had cleaned the filters. I did it, and it worked great. Check the manual for where the filters are and hit them first before getting a new bulb. Hope it helps!
Same problem any body help
