RCA 3-Device Universal Remote with Dedicated DVD Menu Key Logo
K
Kushelia Sukhu Posted on Feb 25, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I reset my remote? - RCA 3-Device Universal Remote with Dedicated DVD Menu Key
Level 3:
Top Expert:
  • RCA Master 76,851 Answers
  • Posted on Feb 25, 2016
RCA Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15004934
Points
237762
Just take out the battery from its compartment; and re- insert it after 5 minutes or so. The remote control will reset itself.
http://remotesearch.blogspot.com/
Where is the reset button on the veon remote?
The location of the reset button on a Veon remote control may vary depending on the specific model, but in general, the reset button is usually located on the back of the remote control. Look for a small, circular button that may be labeled "Reset" or "RST".
To reset the Veon remote control, press and hold the reset button for a few seconds until the LED light on the remote control turns off and then turns back on again. Release the reset button, and the remote control should be reset to its default settings.
If you're unable to locate the reset button on your Veon remote control, consult the user manual or contact the manufacturer for assistance.
1helpful
2answers
HOWTO RESET tv remote TT-76
To reset a TV remote model TT-76, please follow these steps:
Remove the batteries from the remote control.Press and hold down any button on the remote control for about 5 seconds to discharge any remaining power.Release the button and then press and hold down the "Power" button on the remote control.While holding down the "Power" button, insert the batteries back into the remote control.Continue holding down the "Power" button for another 5 seconds.Release the "Power" button and then press the "Power" button again to turn on the remote control.The TV remote TT-76 should now be reset to its default settings.
How do you reset the remote for the ht-r520
To reset the remote for the Onkyo HT-R520, you can try the following steps:
  1. Locate the "Reset" button on the back of the remote control.
  2. Press and hold the "Reset" button for about 5 seconds.
  3. Release the button and wait for the remote to reset
2answers
DC Blue and PLUS reset ? remote lost, connect new but memory full
If you have lost your remote for your DC Blue and PLUS garage door motor and need to connect a new remote, but the memory is full, you will need to reset the motor to clear the memory before programming the new remote.
To reset the DC Blue and PLUS motor, follow these steps:
  1. Locate the reset button on the motor. It is usually located near the bottom of the motor and may be labeled "Reset" or "Learn".
  2. Press and hold the reset button for about 10 seconds until the LED light on the motor flashes rapidly.
  3. Release the reset button and wait for the LED light to turn off. This indicates that the motor has been reset and the memory has been cleared.
Once you have reset the motor, you can program your new remote by following the instructions in the manual. If the memory is still full and you are unable to program the new remote, you may need to delete some of the stored remotes from the motor's memory to make room for the new remote.
To delete stored remotes from the motor's memory, follow these steps:
  1. Press and hold the "Learn" button on the motor for about 10 seconds until the LED light starts flashing.
  2. Press the button on the remote you want to delete from the memory.
  3. Wait for the LED light on the motor to flash rapidly, indicating that the remote has been deleted from the memory.
Repeat these steps for each remote you want to delete from the memory until you have enough space to program your new remote.
If you are still having trouble programming your new remote or resetting the motor, you may need to contact a professional technician for assistance.
1helpful
3answers
How do I reset my tv without remote control?
Without the remote control, you can not do a factory reset; Can only of the hard reset. There are two methods to reset TVs. The first is simple to do; Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it to reset system [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the website linked here. Pull up older posts. Http://electronicshelponline.blogspot.com/
Service entry mode, adjust and exit procedure to many popular brand are given Beheerder TVs. Never forget to exit the service mode, after all adjustments Have Been done.
2answers
Need sansui 076k0ut011 led tv remote codes to program an rca tv
reset sansui tv remote control 076k0ut011 Questions ... - Fixya
www.fixya.com > Forum > Tags
...your help in advance. need code for a one for all URC-2060B06 sansui tv try these ... ...sansui tv with a RCA 704 remote control I have sansui tv and a RCA 704 remote ... URC-3021 Remote Control: How do i program this remote to a sansui tv? ... TV Remote Controls Sansui Remote eBay NEW Orion Sansui JVC LED TV ...
reset sansui tv remote control 076k0ut011 Flat Panel ... - Fixya
www.fixya.com > ... > Tags > reset sansui tv remote control 076k0ut011
Flat Panel Televisions reset sansui tv remote control 076k0ut011 questions and answers. ... ...sansui tv to program rca remote to it model # HDLCD1955C need tv code for this model ... Question about Contex 39-inch 1080p LED TV LE39D3.
Original Sansui - Orion TV Remote Control 076K0UT011 ...
? 1:00
https://www.youtube.com/watch?v=mPbRsUI0xnk
Dec 21, 2012 - Uploaded by ElectronicAdventure
Original Sansui - Orion TV Remote Control 076K0UT011 - Save $5 with ... have the New Original Remote ...
[PDF]Operating Instructions For 4-Function Cable
How do you reset a element flat screen tv when you don't have code
Try Master remote, In this remote Reset button is available or Some time reset button is hidden in default remote. Open remote and see on PCB reset button. Final update firmware.
How to reset model UC7033T
Take out the batteries from its battery compartment. The remote control will reset itself.
50helpful
3answers
I have the Trio Outdoor Lightshow Tree from Gemmy. It worked great until we had to replace the batteries in the remote. I have tried to reset both the box and the remote, but no luck.
push the reset botton on the box in the tree, on the back if the remote there is a reset bottom, push the reset botton on the tree until the light start to blick then push the reset botton on the remote, thats what i did to mine
4helpful
2answers
My remote does not work
Reset remote. If universal remote, put on dvd mode.
  • If your remote has a Reset button, take out the batteries and press the Reset button for 2 or 3 seconds. Re-inset the batteries and try using the remote again.
  • Note: Many remotes have a small hole marked Reset instead of a raised Reset button. To activate the Reset function, you need to push a thin, rigid wire (for example, a straightened paper clip) into the hole to "press" the Reset button. Also, the Reset button or Reset hole may be located under a sliding cover on the lower section of the remote.
  • Remove the batteries and hold down the POWER button for 1 minute. Insert fresh batteries and try using the remote control again.
  • If this does not solve your problem, remove the batteries again and press and release each button on the remote control once, then repeat. Re-insert the batteries and try operating your remote again.
Otherwise you need a new remote. If under warranty call manufacture to see about getting one free of charge. They can also help you purchase a new one if not under warranty.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
