SOURCE: Ricoh Aficio 2035e SC542 service code
Actually the code is for fuser. Here you go.
To get in the service mode is reset 107 hold clear button.
To clear out the code go into service mode turn off and on machince. If that does not work. The solution is below. Hope this helps.
Fusing temperature warm-up error
The fusing temperature does not reach
the fusing standby temperature of 45oC
(113oF) within 9 seconds for the B135
(35 cpm) 14 seconds for the B138 (45
cpm) after switching on the main power
or closing the front cover, or 40
seconds after reaching 50oC the fusing
roller does not reach warm-up
temperature.
Solutions
• Fusing lamp defective
• Poor fusing unit connector
• Thermistor warped or broken
• Thermostat has tripped
• BICU defective
• Power supply board defective
SOURCE: Ricoh 1515 MF shows error code sc542
Um.. I don't see an "online" or "escape" button anywhere on the printer...
SOURCE: ricoh 3245c code is SC542
A SC542 error is a fuser problem. Did you have a power problem? You can try to reset it by turning the copier "ON" and once you have the code displayed on the screen.... Press the Yellow clear botton once - then the #'s 1 - 0 - 7, one at a time then press the Red Stop botton till the display changes..... Once, it changes turn the Main Power Off, not the one on the control pannel. Then turn it back "ON" and that should take care of it for you.... If it did not, you may have some more problems that can not be reset till they are repaired.. Good Luck
SOURCE: ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
SOURCE: Ricoh Aficio #1045 service code # SC542
Try this !
Press yellow "c" buton, type 107 and then press and hold the orange "c" button for 3 seconds.
You will hear a "bip" and the machine should enter the SP mode.
Now just turn off the main power switch located on the left side of the machine. Turn it on again and see if the error appears again.
