The TV will play perfect(ly) for about 20 minutes then turn itself off, in about 3 minutes comes back on for 2 minutes and cuts off again. This is a repeated process and each time the on time gets shorter and the off time gets longer. Do I need a new power supply and if so how can I tell which board is the power supply board?
** If you don't know what your doing back there, probably best not to go poking around. Power supply capacitors can bite hard and unmercifully, even when they've been unplugged for days. If you know how to safely discharge them, then do this before you touch anything. Until this is done, Keep one hand behind your back at all times, and this is no joke. To locate the power supply, follow the connections from the AC cord that go into the TV. The board that these wires are connected to is the power supply. Plenty of videos online about how to locate bad capacitors. Which is a very common problem in some tv's.
