Proscan 7.85-Inch Android Tablet Dual Core Processor Android 4.2 Google Play Certified Logo
r
roger harman Posted on Feb 23, 2016
PROSCAN PLT7100G has authenticatin problen to router
My Proscan Tablet won't connect to CasinoRPG it is always coming up AwSnap, can anyone help me
Hi try this :::: select "tools" & then click "extensions" disable an extension & restart browser ....good luck
1helpful
Firmware for proscan plt7100g
The only firmware for the PLT7100G is available here: http://www.proscanvideo.com/item.asp?itemnmbr=PLT7100G . The direct link to the firmware is http://www.curtisint.com/html/custservice/manuals/PRO_PLT7100G_FIRMWARE.ZIP .
Unfortunately, this firmware update may not help with the app problem that you are having.
How do I right click a tablet?
Touch and hold for a couple of seconds. You should then get some sort of options menu if what you touch supports it.
My tablet is asking for a password to decrypt storage. where do i get a password from
if you're not the first owner then that person put encrytpion on. Now you're either to contact the previous owner or re-flash your device from scratch.
User manual for proscan PLT7100G
You may be able to uninstall some of the apps. Go to the applications page by touching the icon with the 6 squares in a circle. Then go to APKInstaller menu. Click (or touch) the Manage option. Select the APK for the app that you want to remove. (Some items may not be removable since they will be part of the OS. They won't have a separate APK installer.)
The manual for the Proscan PLT7100G is available from the manufacturer's product site: http://www.proscanvideo.com/item.asp?itemnmbr=PLT7100G . The direct link to the manual is http://www.curtisint.com/html/custservice/manuals/PRO_PLT7100G_ENFR.PDF . The uninstall information is on page 17 (page 18 of the PDF).
I hope this helps.
Top Proscan Tablets & eReaders Experts
 Mikey
Mikey
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Proscan Tablet and eReader Expert? Answer questions, earn points and help others
