SOURCE: how to bring back the router function of zyxel P600 w/o password
You can simply reset the device to factory defaults. There's a reset button at the back of it. Hold it down for 30 second with the power on. That will reset the unit back to router function.
SOURCE: im using zyxel p600 : problem from router then to
Only 1 PC is able to go online. check the IP address on that PC.
and make sure that it is a private IP address. You have a switch also.
why do you need a switch if you have only 2 computers in the network.
If you have a router then you can connect both the computers directly to the router.
Click Here for more info about networking.
SOURCE: zyxel modem and wrt54g modem
1 first thing you do, go to web based utility 192.168.1.1 login to the zyxel modem....then go to tool => configuration => reset.....
2. configure your router, go to web based utility 192.168.1.1 login ti the router....then go to basic set-up choose DHCP automatic confg... enabled dhcp 192.168.1.100
max dhcp user its up to you....
3. advanced routing choose gateway.....select set number 19 .... then interface lan and wireless....
4. connect all the cable attached.... then checked the status is connected.....
5. set your LAN into DHCP....
