Microsoft Windows XP Professional for PC Logo
plazaneju Posted on Feb 22, 2016
Windows xp3 bootable usb iso file - Microsoft Windows XP Professional for PC
Avinash Verma
Level 1:
Habit-Forming:
New Friend:
  • Contributor 11 Answers
  • Posted on Oct 02, 2018
Avinash Verma
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
11
Questions
0
Helped
4577
Points
66
Norbert Fernandes
Level 1:
New Friend:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Feb 22, 2016
Norbert Fernandes
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
15
Questions
0
Helped
5212
Points
28
Use yumi to create a bootable usb (the first link)
the second link is the iso file
also it is recommended not to use windows XP as your main operating system. If you are using for research or something else then its alright.
YUMI-http://www.pendrivelinux.com/yumi-multiboot-usb-creator/
Win XP SP3 - http://offlineinstallersoft.blogspot.com/2015/03/windows-xp-pro-sp3-iso-download-free.html#.VssLKxjxVxg
there are official links too and also guides.
2answers
How to reinstall corrupted windows 10
Place your install media in a drive and boot from it, choosing fresh install.
Hello i m facing some problem i cant boot my windows through usb drive i will explain the process i have did to boot from usb drive. Before that i will give some information about my system please note...
Most of those Windows to USB applications are for creating an Windows USB installation, not actually installing an operational OS on the USB. Does that make sense?
You would have to run the setup and choose the drive to where to install the OS. This would mean you would have to do it from a CD/DVD disc or have two USB drives, but this may cause a conflict.
Windows 7 instaiiation disc
http://download.cnet.com/windows-7-usb-dvd/3000-18513_4-10972600.html
When you purchase Windows 7 from Microsoft Store, you have the option to download an ISO file or compressed files.
The Windows 7 USB/DVD Download tool allows you to create a copy of your Windows 7 ISO file on a USB flash drive or a DVD.
To create a bootable DVD or USB flash drive, download the ISO file and then run the Windows 7 USB/DVD Download tool.
Once this is done, you can install Windows 7 directly from the USB flash drive or DVD.
Hope it helps
2answers
I changed my username now my password won't work this is on another computer.It ia a dell windows 7.It don't have a place for a disk
Go to the link below and download Ophcrack and burn the iso to a bootable USB Pen Drive... Boot from the bootable USB Pen Drive and let it do it's magic. You'll have the password shorthly:
http://ophcrack.sourceforge.net/download.php
Boot from usb
Introduction UNetbootin allows you to create bootable Live USB drives for Ubuntu, Fedora, and other Linux distributions without burning a CD. It runs on Windows, Linux, and Mac OS X. You can either let UNetbootin download one of the many distributions supported out-of-the-box for you, or supply your own Linux .iso file if you've already downloaded one or your preferred distribution isn't on the list.
Requirements
  • Microsoft Windows 2000/XP/Vista/7, or Linux, or Mac OS X 10.5+. Note that resulting USB drives are bootable only on PCs (not on Macs).
  • Internet access for downloading a distro to install, or a pre-downloaded ISO file
Features UNetbootin can create a bootable Live USB drive, or it can make a "frugal install" on your local hard disk if you don't have a USB drive. It loads distributions either by downloading a ISO (CD image) files for you, or by using an ISO file you've already downloaded.
The current version has built-in support for automatically downloading and loading the following distributions, though installing other distributions is also supported:
2helpful
2answers
I want to make my pendrive bootable to install window xp on my computer
download this file unetbootin-windows-471.exe, then you must have an ISO file of your windows xp, you can install ultraiso or any iso maker available on the web, insert your xp cd then make an iso image out of your xp cd... after having iso file for win xp, insert your pen drive (at least you have 1gig free space on your pen drive) then open unetbootin-windows-471.exe, under the disk image, locate your win xp iso file using the select disk image file button,. then just chose Usb Drive , and also on the drive chose the drive of the usb (check it on my computer and check the drive letter of your pen drive) then click ok... once successful transfer of image to the pen drive, restart pc then make your pen drive to be the 1st boot device
Need a password
Dear i have send some instruction of need a password.
please follow the instructions.
and you receive a password.
Thanks.
1. Download a free demo version of Windows Key (to reset a "Demo12345" password for a trial) or buy an instant download online (to reset an unknown password)
2. Run the downloaded file to install Windows Key. You can install Windows Key on any PC you have access to
3. At the end of the installation process enable the "Run Windows Key" check-box and click the "Finish" button. Windows Key will be launched automatically
4. Create a password reset CD, USB Flash drive or a driver floppy following the instructions below:
Using a Windows Key bootable CD 1. Click the "CD image" link
2. Insert Windows Setup CD and browse for the TXTSETUP.SIF file. The file is usually located in the 'I386' folder of the Windows Setup CD. Click "Next" (Don't have any Windows Setup CD? Request a Windows Key .ISO download)
3. Enter you name and set your own password for the bootable CD (you may set an empty password). Click "Next"
4. WindowsKey.iso file is created
5. Insert a blank CD, specify your burning drive from the list and click "Next"
6. Windows Key password reset CD is ready
What should I do next?
7. Reboot your system with this CD
8. Windows Setup process starts
9. After all the required files are loaded from the bootable CD, Windows Key starts working. It displays your license info and asks to enter the password that you set for the bootable CD
Continue to step 14*
Using a Windows Key bootable USB Flash Drive 1. Click the "USB Flash Drive" link
2. Connect a blank USB Flash Drive. Click "Next"
3. Insert Windows Setup CD and browse for the TXTSETUP.SIF file. Click "Next" (Don't have any Windows Setup CD? Request { /iso-request.htm } a Windows Key .ISO download)
4. Enter you name and set your own password for the bootable USB Flash Drive (you may set an empty password). Click "Next"
5. Windows Key password reset USB Drive is ready
6. Reboot your system with this USB Drive. To reboot your PC with USB Flash Drive you may need to set the following options for the BIOS Setup Utility: after rebooting your PC please press "Del" or "F2" to run BIOS Setup Utility, go to the "Boot" section and press "F6" to move the "Hard Drive" device up, press "Enter" on the "Hard Drive" option and press "F6" to move the "USB Drive" device up. After all the changes are set please press "F10" to exit and save the settings
7. Windows Setup process starts
8. After all the required files are loaded from the USB Drive, Windows Key starts working. It displays your license info and asks to enter the password that you set for the bootable USB Flash Drive
Using a Windows Key driver floppy 1. Click the "driver floppy" link
2. Insert a blank floppy into the floppy drive and click "Next"
3. Enter you name and set your own password for the driver floppy (you may set an empty password). Click "Next"
4. Windows Key creates three files on the floppy: winkey.sys, winkey.inf and textsetup.oem. The driver floppy is ready What should I do next?
5. Insert Windows Setup CD or bootable floppy and reboot your PC
6. Windows Setup blue screen appears
7. Press "F6" when Windows Setup prompts for additional drivers at the bottom line of the blue screen
8. Windows Setup continues loading required files from the bootable CD or floppies
9. Windows Setup prompts you to press "S" to specify additional drivers. Press "S" and insert the Windows Key driver floppy
10. Press "Enter" to specify the "Windows Key" driver
11. Windows Setup loads the files from the floppy drive
12. Windows Setup continues loading the files from the Setup CD or prompts you to continue with the rest of the bootable floppies
13. After all the required files are loaded from the Setup CD or bootable floppies, Windows Key starts working. It displays your license info and asks to enter the password that you set for the driver floppy
Boot Mode 14. Please enter the password that you have set for the Windows Key bootable media
15. Select the Windows installation to be unlocked
16. Windows Key asks: "Undo Windows Key changes? (Y/N)". Press "N" if you want to reset the password or "Y" if you want to leave the original passwords and cancel the program changes
17. Select the account to reset the password for
18. Windows Key asks: "Reset 'account_name' password? (Y/N)". Press "Y" to reset the password or "N" to leave the original password
19. Windows Key asks: "Reset password for another account? (Y/N)". Press "Y" to reset password for another account or "N" to quit Windows Key
20. Remove the Windows Key bootable media and restart your PC.
3answers
How to make bootable disk with win xp.iso format?
to answer the first question an Iso file can be burned to disk using the iso
burning function that comes with most burning software. if this file is an operating system then it would automatically be burned as a boot disk and nothing else would be needed. However if this is say service pack 3 and its an iso format then even though your burning it using an iso function it would just be service pack 3 and nothing else a none boo table disk.
Windows vista
How To Make Vista Bootable DVD with WIM Downloaded Files If you have purchased Windows Vista online and taken the delivery of the latest operating system via web download from Windows Marketplace, you would ends up with a few downloads with .wim and .exe file extensions. Rather than paying additional shipping and handling charges, you can burn or create a bootable ISO DVD image from downloaded Vista files with the following trick, where the .iso image can subsequently write to a DVD. The DVD created will be the typical 32-bit Windows Vista DVD that available in retail channel, and can be used to clean install.
How to make a bootable Windows Vista ISO DVD media
1. Put all 3 downloaded files (namely install.wim, boot.wim and an executable X13-49120.exe) in the same folder (for this tutorial, let’s assume the files are put on C:\ else you need to modify the path accordingly).
2. Run the X13-49120.exe executable. Windows Vista Setup Preparation will create a new folder “Vista” inside the folder and will populate the folder with all necessary Vista setup files which takes up about 2.52 GB disk space.
3. Exit from the Install Windows screen.
4. Download CDimage 2.52
5. Extract CDimage from CDimage.zip to the C:\ root directory.
6. Open a command prompt shell, and run the following command:
cdimage.exe -lVISTA_EN_DVD -m -u2 -bC:\Vista\boot\etfsboot.com C:\Vista\ C:\Vistax86.iso
Bootable Windows Vista x86 DVD ISO image in UDF format will be created as vistax86.iso in C:\ or any folder you specified above.
7. Burn the newly create ISO with a CD/DVD burning software such as Nero or Alcohol 120%. Try to burn at low speed (i.e. 4X) and turn on verification to ensure that the DVD creation is fine.
Create a Windows Vista ISO image and DVD with Oscdimg
Another possible way to create a bootable Vista ISO and DVD is by using Oscdimg CD-ROM and DVD-ROM Premastering Utility, available via WinPE (Windows Preinstallation Environment) via Business Desktop Deployment 2007 or Windows Automated Installation Kit (AIK)
1. Complete step 1 - 3 as above.
2. In the command prompt window, run the following command:
oscdimg -bC:\Vista\boot\etfsboot.com -h -u2 -m -lVISTA_EN_DVD C:\Vista\ C:\VistaDVD.iso
A VistaDVD.iso UDF DVD image will be created and can be used to boot the computer from DVD to install Vista.
3. Burn the ISO image file by using last step above.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
