I pulled the belt and th motor turns. But only in one direction. I tried turning the transmission it will turn but only in one direction. Which handles the agitation the motor or the transmission?
SOURCE: agitated with my agitator and spin cycle
Your problem could be with your transmission, which is located directly above the drive belt pulley under the wash tub. If they go bad, your motor will still function normally, but the wash tub will not spin or agitate. Now, another possible problem could be a nail or screw stuck in one of the wash basket holes pressing against the outer tub. I have personally seen this a couple of times. A dry wall screw or nail will stop the wash tub from spinning and cause the drive belt to smoke as the motor pulley turns, but the belt stays stationary. That could be the source of your smell. If you're a do-it-yourselfer or do a lot of carpentry work, you may have washed some clothes with a nail or screw in them. Inspect all the holes in the wash basket throughly. A nail or screw can easily be missed if your not looking for it. I hope this may help you.
SOURCE: Agitator not spinning
could'be water level switch or timer control. another posibility is corrosion on the motor wiring connector
SOURCE: Agitator not turning during cycle
Well, it sounds like you've done your homework. My first suspect would have been the agitator dogs too, but you said they were fine. Another likely suspect would have been the motor coupler, but you said the washer spins during the spin cycle. If the coupler was bad the unit would fill, but wouldn't agitate or spin. Plus, it would make an awful noise. I would have also suspected a clutch assembly, but you said the wash tub can spin. Normally, when the clutch goes bad, the drum won't spin, or spins slow. Another suspect could have been a bad lid switch, but the washer would have filled and stopped, without agitating or spinning. The only remaining suspect that I'm aware of is the gear case (transmission). Checking under the washer can give you some clues. Normally, when a gear case starts to go bad, they leak an amber colored oil. You may find puddles or drips under the washer. If you see no signs of oil the gear case could still be defective, however. But, before you go through all the trouble, double check the agitator one more time. Completely remove it from the tub and check the under side to ensure the grooves that grip the top of the gear case shaft have not been worn smooth. I hope this may have been some help to you.
SOURCE: Kenmore 70 Series Washer Spin Cycle Only issue.
It sounds like one of two things 1,A worn clutch .or 2.motor coupler is about gone,
SOURCE: Kenmore 90 series won't agitate, spin or drain
hello there,
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If your washer pumps out the water but doesn't spin, check these:
For
safety, washing machines are made so that they spin only with the lid
closed. The lid switch prevents the spinning action when the lid is up.
Drive pulleys
The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission
The transmission could have either of these problems:
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator
The
inside of the agitator--where the transmission shaft attaches--can
become worn, and strip out the spline that allows the agitator to
properly grip the shaft. Then the transmission shaft rotates back and
forth as it should, but the agitator doesn't move properly. If this
happens, you may need to replace the agitator and/or the transmission
spline
