SOURCE: Control Locked light is on...
OMG!! I just held the button at the end of cycle signal for about 3 seconds and the light went off! Now my washer is working!
Ok Yankee
push and hold in far right button on conrtol panel( look closly you see control lock) hold for 3 secs and it will turn off
SOURCE: control locked
It is recommended to try putting the machine into diagnostic mode. If it won't enter
diagnostic mode, then you need to replace the main control board.
DIAGNOSTIC TEST
The washer must be empty and the control must be in the OFF
state before pressing the touch-pad sequence to start the test.
Starting the Test Mode
■ Close the door.
■ Push CONTROL/ON (if present on this model).
■ Select the DRAIN/SPIN cycle.
■ Select NO SPIN by pressing the SPIN SPEED touch-pad.
■ Push PREWASH OPTION four times within five seconds. (If
PREWASH OPTION is not present on this model, press EXTRA
RINSE four times within five seconds.) C:00 will light up on the
display.
If the Starting procedure fails, push the PAUSE/CANCEL touch-pad,
then repeat the starting procedure.
Test Program Control
In order to advance to the next step of the test procedure, push
PREWASH OPTION touch-pad two times. If PREWASH OPTION is not
present on this model, press EXTRA RINSE two times.
Let me know how this goes and whether you need any further help
good luck and please let me know if you have any questions when doing this
SOURCE: "Control Locked" light is lit. Washer won't start now.
Hi
Thanks for using FixYa. Press and Hold the "End Of Cycle" button so that it resets itself. Please do rate the solution
if the issue is resolved or else revert for further assistance.
Thanks
Rylee
SOURCE: control locked light is lit and the machine will
Hi
Thanks for using FixYa. To unlock the controls and resolve the issue you’ll need to press and hold the END OF CYCLE button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
The Control Lock prevents unintended use of the washer. You can also use the control lock feature to prevent unintended cycle or option changes during a cycle. When CONTROL LOCKED is lit, all buttons are disabled except for Pause/Cancel and Start.
You can lock the controls while the washer is operating.
To lock the controls:
Select and hold DRAIN & SPIN for 3 seconds. The CONTROL LOCKED status light glows.
To unlock the controls:
Select and hold DRAIN & SPIN for 3 seconds or until the CONTROL LOCKED Status light turns off.
