Ooooh, despite what has been advised, do not use WD-40 on your sewing machine. It is best to use Tri-Flow Synthetic Lube. WD-40 is a penetrant that will work in the interim but will turn to glue with age, landing your machine in the same predicament it is now experiencing.
Wheel on right side that controls the needle up and down is very tight...
There is a lever for positioning the needle bar. When you move the lever to the left middle or right , the needle bar too should follow the same. Try to do that. If it doesn't follow the lever and stays at one end, that means the machine needs to be oiled. Not like most sewing machines Supernova swings the bottom rod too to left and right when Zig Zag is engaged. I recommend to spray some WD 40 first, to inside of top and bottom side of the machine , and later to apply machine oil to every moving joints.
SOURCE: Zig Zag Skip Stitch
your machine might have a problem with the rotary hook, it might need to get timed by a professional.
SOURCE: I have a Necchi supernova Julia 534
sounds to me like a tension issue, also are you using rayon or polyester thread, this is just a recommendation for those types of threads,,,,,,but please check your tension, is it only doing it during automatic
SOURCE: Stitch length control knob broken on my Necchi Supernova Julia
Contact Necchi directly (800-525-9987) and speak with the Service manager who may be able to get the part for you if they are available anywhere.
sewman7
SOURCE: do you have user manuals for necchi supernova automatic?
Join the yahoo users group for Necchi. It's fabulous, and we have the manuals available online for free there, plus lots more..
SOURCE: How do I use the automatic bobbin winder on Singer
Here is a guide for bobbin winding and threading the 457 - http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_457_stylist_threading_diagram.htm
