Question about Canon PowerShot A620 Digital Camera
Memory card error
Over the weekend i bought and installed an 8g dane-elec on my canon a620 camera. when i turned it on it said memory card error. i thought perhaps that the sd card was defective that i returned and replace it with a lexar 4g sdhc card. but the same error is still showing. i tried locking and unlocking the lock mechanism on the card but to no avail. what do you think is the problem?
  • 346 Answers
The memory card could be too big. Some camera's can only use a certain size memory card. You will have to check your manual to see what the specifications for your memory cards. Hope this helps.
Posted on Jul 16, 2009
Anonymous
SOURCE:
Can I use 8GB SD cards in my Canon Powershot A620 camera? I thought I once read that it will only support up to 2GB SD cards.
The A620 uses MMC and SD cards. SD cards max out at 2GB in size. Larger cards are actually SDHC or SDXC cards and will not work in the A620.
Jan 11, 2011 | Canon PowerShot A620 Digital Camera
I have a Canon Power Shot A620 PC1145. I recently bought an 8GB SDHC card. When I put it in the camera. I got "memory card error" I was unable to do anything with it. I had hoped to take it on holiday...
The A620 works with MMC and SD cards. While SDHC cards will fit into the slot, they will not work. You need to use SD cards 2GB and smaller.
Sep 20, 2010 | Canon Cameras
Bought new sdhc memory card and it reads memory card error please help
The A620 is designed to work with SD cards, not SDHC cards. SDHC cards will fit into the slot but are electronically different. You'll have to stay with SD cards, 2GB and smaller.
Jul 03, 2010 | Canon PowerShot A620 Digital Camera
I have a Canon SD400 Powershot digital camera. It
First, make sure your camera can accept SDHC cards. If the camera says the card is locked, move the slide switch on the side of the card.
Jun 13, 2010 | Canon PowerShot SD400 / IXUS 50 Digital...
When I inserted the new memory card (SanDisk Ultra II, 4GB) into my Canon PowerShot A620, it tells me "Memory Card Error". This is a brand new card. What do I do? It had been working just fine with a...
Some cameras cannot handle over 2GB memory cards. If it works fine with 2GB card - stick to that. If some other A620 you know operates with 4GB card, take yours to repairs.
Oct 24, 2009 | Canon PowerShot A620 Digital Camera
Put new SanDisk 4GB card in Canon A620 and get Memory Card Error
The A620 came out in 2005, before the SDHC (high capacity) protocol had been introduced. The A580 came out in 2008 and is compatible with the SDHC protocol. The A620 is only compatible with the SD protocol, and maximum capacity under this protocol is 2MB.
Aug 27, 2009 | Canon PowerShot A620 Digital Camera
I put a brand new SanDisk SDHC 4 GB memory card in and it says "memory card error; card is locked".
I also own an A620, but unfortunately I also learned the hard way that SDHC cards are not compatible with this camera. The A620 was designed before the newer SDHC format came out, thus although they look exactly the same, your camera will never work with these cards. Your camera uses standard SD cards (2GB or less). There are some standard 4GB SD cards, but they are very rare these days, and costly.
Aug 06, 2009 | Canon PowerShot A620 Digital Camera
Canon PowerShot A620 says no memory card when there is a memory card installed. Tried two different cards and both not working. Card is not full or locked. Card door closes all the way. Owner's manual's...
Your camera has a board with the SD card slot board and electronics to record and retrieve images. This board can be replaced and should cost about $100 to repair.
Jul 02, 2009 | Canon PowerShot A620 Digital Camera
Canon PowerShot A620 Digital Camera Logo
479 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
