Question about Dishwashers
Dishwasher smells like a dirty auto repair shop
After running a baking soda and vinegar cycle, the odor is now coming from the drains in adjacent sinks. How can we correct this?
  • 588 Answers
Do you have an airgap valve on top of your sink or counter? Some times routed through an exterior wall. Their purpose is to prevent dirty water coming back into the DW and sitting. You can tell by looking under the sink as well. Your DW drain should never go directly to your garbage disposal or peetrap.
Posted on Feb 20, 2016
  • John Baker
    John Baker Feb 20, 2016
    Thank you for your response. Yes, we do have an air gap valve on our counter.
Anonymous
SOURCE:
How to get vinegar smell out of ac window unit
hi Jeff.
not saying this will work,but its all i could find on the internet.
Sprinkle baking soda on the surface being cleaned (as long as it is safe to do so). Scrub with a sponge or plastic brush to work in the baking soda. Rinse with clean water and the vinegar smell should disappear.24 Dec 2009
How to Get Rid of a Vinegar Smell ' Hunker
https://www.hunker.com/12001359/how-to-get-rid-of-a-vinegar-smell
What will neutralize the smell of vinegar?If the smell of vinegar lingers and you just hate the smell, open a box of baking soda and leave in the room that smells. The baking soda will neutralize the smell of thevinegar.What are some ways to get rid of the vinegar smell without removing ...https://www.quora.com/What-are-some-ways-to-get-rid-of-the-vinegar-smell-without-re...Search for: What will neutralize the smell of vinegar?
How do you get the smell of vinegar out of a car?Sprinkle baking soda over the carpet before vacuuming it to remove odors.Blot the area affected by the vinegar if it is still damp. ...Sprinkle baking soda over the affected area of carpet and let it sit for about an hour.Vacuum the carpet thoroughly.Reapply more baking soda and vacuum again if necessary.How to Remove a Vinegar Smell From Carpet ' Hunkerhttps://www.hunker.com/13421004/how-to-remove-a-vinegar-smell-from-carpetSearch for: How do you get the smell of vinegar out of a car?
or go to this link might help you out more.
How to get vinegar smell out Google Search
Nov 26, 2017 | Heating & Cooling
Tip
How to Sanitize Your Dishwasher
Step 1 -
Get rid of any odor that may be coming from the plumbing pips your dishwasher shares with the sink. Pour a half of cup of baking soda down each sink drain. Pour cups of vinegar down each drain until all of the baking soda is washed away. After five minutes, run very, very hot water down each of the drains.
Step 2 -
Clean out your garbage disposal. Slice a lemon/lime and put the slices down your disposal drain. Run your disposal with cold water running.
Step 3 -
Pour two cups of vinegar into the dishwasher and let it sit for an hour and then let the dishwasher run through a cycle with the hottest water possible. Repeat the process is that does not clean up all of the build and film. You can use baking soda and bleach instead of vinegar - just sprinkle the baking soda in the bottom of the dishwasher tub, and pour bleach inside the tub as well.
Step 4 - Between washes, pour 1/4 cup of lemon juice into the dishwasher cup and run a short, but complete wash cycle. This will not only deodorize the dishwasher but will also help get rid of any metal build-up.
on Oct 19, 2011 | Frigidaire Dishwashers
Tip
Clean a Dishwasher
How To Clean A Dishwasher
  1. Using a small brush (old toothbrushes work well) dipped in hot water and white viniger, go around the door of the dishwasher taking care to get into the grooves and crevices of the rubber seal. Most likely, you'll be surprised at the debris that has built up, especially at the bottom of the door and around the hinges on the side.
  2. Pull the bottom rack out and examine the drain area. Wipe around it to be sure there are no hard chunks that can plug the drain, cause damage to the pump or scratch dishes. You'd be surprised at what dishwasher repairmen find - bones, crab shells, chips of glass, and even small pieces of gravel!
  3. Using a clean wet sponge or dishrag, wipe the cleaning solution from the gasket and the door.
  4. Then place a dishwasher-safe cup filled with plain white vinegar on the top rack of the dishwasher. Using the hottest water available, run the dishwasher through a cycle - except for the cup of vinegar, the dishwasher needs to be empty.
  5. The vinegar will help to wash away the loose, greasy grime, sanitizes, and helps remove the musty odor.
  6. Baking soda is also effective at freshening and brightening your dishwasher. Just sprinkle a cupful around the bottom of the tub and run it through a short but complete cycle using the hottest water. Baking soda is also helpful in removing stains.
on Jun 19, 2011 | Dishwashers
Is there something to clean out for waste? Dishwasher is stinky
Method 2 Removing Smell with Vinegar and Baking Soda
  • Place one cup (8 oz) of distilled white vinegar in the top rack of the dishwasher. ...
  • Run the dishwasher for a full cycle. ...
  • Sprinkle a cup of baking soda over the bottom of the dishwasher. ...
  • Run an additional cycle.
3 Ways to Clean a Smelly Dishwasher - wikiHow
www.wikihow.com/Clean-a-Smelly-Dishwasher https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=Dishwasher+is+stinky
Dec 02, 2016 | Dishwashers
I spilled baby milk and have bad odor need to clean
I would try using baking soda and soapy water. The baking soda will help remove the foul odor. And febreeze auto clips work wonders. You may need to buy the double pack for a spacious interior. Vinegar is also good for removing odors, but then you'd have that smell in the car. If you choose to use vinegar dilute with water. hope this helps.
Aug 21, 2013 | 2011 Nissan Rogue
We are getting a strong odor from our two compartment dishwasher, would welcome any suggestions
Get rid of any odor that may be coming from the plumbing pipes your dishwasher shares with the sink. Pour a half a cup of baking soda down each sink drain. Pour cups of vinegar down each drain until all the baking soda is washed away. After 5 minutes, run very, very hot water down each of the drains.
Clean out your garbage disposal. Slice a lemon and put the slices down your disposal drain. Run your disposal with the cold water running. You can use just the lemon or an orange rind if you don't have a whole lemon.
Pour two cups of vinegar into the dishwasher and let it sit for an hour and then let the dishwasher run through a cycle with the hottest water possible. Repeat the process if that does not help. You can use baking soda instead of vinegar - just sprinkle it in the bottom of the dishwasher.
Between washes, pour ¼ cup lemon juice into the dishwasher cup, and run a short but complete wash cycle. Is will not only deodorize the dishwasher, but will also help get rid of any metal build-up
Nov 03, 2010 | Fisher and Paykel Dishwashers
Terrible smell
yea disposers are most likely cause of odores backin up into the d/w's you can try running through a cycle with a bowl full of vinegar. the vinegar will flush put of the bowl during wash and get all the nooks and crannies clean
Apr 16, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Admiral Washer smells like mildew
yes it could . If you are trying to pump the water 7 feet or more above the floor then it will at the end of the cycle get air into the drain hose causing cavatation, the result when the machines stops is the water running back down the drain hose back into the tub and that is what causes the musty smell.
Lower the drain if possible
Apr 10, 2008 | Admiral AW22 Top Load Washer
Odor will not go away.............
hi there,
i would let you try putting a small can with charcoal in it inside the dishwasher. However, you cant use it for about 1 weeks' time.
Charcoal absorbs trapped smell.
hope this helps.
Feb 04, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
Marvin
Marvin
