SOURCE: OUT OF MEMORY
Just because you can hear fine when you call the same number and talk to the person there, does not mean a fax machine won't sense noise on the line. A fax machine is much more sensitive, and cannot have a lot of noise or it will not be able to render the image at the other end correctly. So have your phone company and the recipient's phone company check the lines for problems.
There is also the chance that the two fax machines cannot get along. We have clients that we cannot use our fax machine for, because it always generates a similar error to yours. If we go to the other side of our building and use a separate fax machine on a different line, it goes through just fine.
The other half of the error is out of memory. If you have not tried these ideas, try them also: To gain extra memory, you can turn off Fax Storage, print fax messages in memory or cancel a Delayed Fax or Polling Job. In general, shutting the unit off will purge most everything out of memory.
Hello laray7813,
Please visit this link to know exactky what NG means and how to solve it.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000200/000009/faq000209_000.html?reg=us&c=us&lang=en&prod=mfc420cn_us&Cat=12
If this dosent work, let us know and we will find other solutions,
Dahaka
Brother Tech-Support told me to leave it unplugged over-night. I unplugged mine ant 12:00 pm and plugged it in at 9:00 am the next day and it still didn't work, maybe you have to leave it unplugged longer, try 24hrs.
SOURCE: MFC-440CN PRINTER fax error
Plug a phone into the line and listen for static. Too many phones on the line, bad lines,etc, can cause a poor line condition. Try the unit directly into the phone line, no answer machine or anything else on the line. Maybe the memory thing is it has a lot of faxes that it hasn't been able to send.
