Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
SOURCE: nesecito codigo de un control remoto CHUNGHOP PARA UN TV LG
en la pagina chunghop estan los manuales con los codigos. yo necesito un manual de tv itt-nokia sat 203 o alguien que me explique como se programan los canales y el timer.
SOURCE: no encuentro el codigo para programar un televisor
No encuentro el codigo para programar un televisor sankey modelo ct1492z
SOURCE: CODIGOS PARA EL DAEWOOD TV DEL CONTROL REMOTO RCU403A
NO SE EL CODIGO DE MI CONTROL REMOTO RCA 403, PARA MI TV MAGNAVOX..... AYUDENME, PLIS
SOURCE: como saber el codigo para
0023, 0024, 0043, 0044, 0045
Si ninguno funciona, puedes usar la función para buscar códigos del control, para esto hay que:
1.Con el televisor encencido, mantener presionado el botón de TV por al menos 6 segundos hasta que se enciendan las luces de cada dispositivo y la luz de TV permanezca encendida.
2.Presionar POWER, la luz de TV parpadeará 3 veces y se apagará.
3.Presionar la flecha hacia arriba hasta que el televisor se apague, una vez que se apague hay que presionar OK. Al presionar OK, el control guardará el código y ahora podrá controlar el televisor.
