Question about Doro Phone Easy
Speaker phone feature
Does the phone have this feature/
How to stop the hold music from playing through the speaker constantly?
press [Feature] # 86
to turn off Background Music (as Nortel calls it).
F86 to turn on
F#86 to turn off
Sep 29, 2014 | NorStar M7324 Telephone
Does this phone have speaker phone, and if so how do i turn it on?
Yes, there is a speaker option. Holding the phone in your hand look down to the lowest row of buttons - below the * 0 # buttons. There are four buttons: from left to right they are SPEAKER; PAUSE/REDIAL; REMOVE/MUTE; and, INT (INTERCOM.) Pressing the left/SPEAKER button one time turns on this feature. Pressing this button turns OFF this feature. Hope this was helpful.
May 11, 2011 | Vtech 5.8GHz Cordless Phone with Digital...
Cannot hear the ring on a particular phone. The same phone also cannot hear anything when using the "Handsfree" feature, nor can antyhing such as voice mail messages, be heard through the...
There is a speaker test you can do. Press the feature button then on the dial pad press 805 followed by the # key or the next key until you see speaker test in the display. Press the test key or the hold button to start the test. You should hear a page tone at maximum volume. Press any button to end the test, the volume will return to its previous level.
The phone is mute by pressing the handsfree/mute button(bottom left button). sometimes the button labels do not match the feature that is programmed for the button. Press feature * 0 and any button to see what feature is programmed on the button.
Dec 13, 2010 | NorStar M7324 Telephone
I have a NEC DTU-16D-2 phone system. The Speaker
Press Feature and then 1. This will turn on the MIC.
Apr 20, 2010 | NEC DTU 8D-2 Corded Phone
DOSE THIS PHONE HAVE A SPECKER OR HANDS FREE
Yes, that phone have speaker and hansfree feature. Full specs can be found at http://reviews.cnet.com/cell-phones/samsung-sgh-d407-at/4507-6454_7-31814749.html?tag=mncol;psum
Regards,
Jeep Brainy
Aug 12, 2009 | Samsung SGH-d407 Cellular Phone
PROGRAMING PAGE FEATURE ON M7310
First try this. Press FEATURE 601. If that pages all speaker, then I remembered it correctly. If not, Try 6xx 602? 612? until the display says PAGE ALL. That's the feature code.
Now, pick a button. Press FEATURE *3 the button and dial FEATURE 6xx with xx being the code you used above.
Now when you press that button, it will page as you desire.
Carl
May 21, 2009 | NorStar M7310 Phone
Cant find speaker phone feature on my Motorola Razr V3 cell phone
Yes, This phone does have a speaker phone setting.
When in a call it should be the top right button on your keypad.
Dec 17, 2008 | Motorola Mobility RAZR V3
Speaker phone light continually blinks
The blinking light on the speaker button means the forward when busy is on. To cancel it- With the handset on-hook dial #12.
Then press your own station number. Then dial # again. The speaker button should stop flickering.
Note: If the SPK button continues to flicker, Forward all is activated. It is the same process as above but use #11 instead of #12
Feb 21, 2008 | Samsung Prostar 816 Phone
Flashing feature button
Jennifer, if it is a CallBack Request, it will be cleared when you speak with the extension that set it. You can press SPEAKER - "#" to call them back (default setting).
If the phone is in CFWD ALL, clear it by pressing SPEAKER - "42"
Oct 18, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
Doro Phone Easy Logo
50 people viewed this question
Top Doro Lands Phones Experts
Marvin
Marvin
Vernon Taylor
Peter Dragonetti
Are you a Doro Lands Phone Expert? Answer questions, earn points and help others
