SOURCE: kodak easyshare z1275 not working =(
PROBLEM - Camera will not turn on at all regardless of battery used. Happened after about 8 months of use. Kodak instructed me to send the camera in of warranty repair. MCU was replaced. The unfortunate thing is that I have the same problem again, 7 months later and I am guessing it is not a warranty repair this time.
SOURCE: USB DEVICE NOT RECOGNIZED KODAK EASYSHARE C913
remove you memory card
turn camera ON > Press Menu > go to setup menu> format internal memory>
take 1-2 picture > reconnect your camera to the computer>
if the camera will be recognized> reinsert the MMC> format the MMC > it will delete all your pictures including the corrupted ones
most of the time its just a MMC issue
good luck
SOURCE: Kodak easyshare C182 camera. It is six days old
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
Contact KODAK:
SOURCE: batteries in my kodak easyshare camera don't last
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Turn on your camera without the memory card.
In order to organise your repair or Trade up please Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
SOURCE: kodak easyshare c643 - batteries are fresh, but it
If the camera has recently been dropped you may have lens damage that is preventing it from powering up. If it hasn't been dropped your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Testimonial: "Thanks for the help!"
