Model number : 050507075
SOURCE: Stoves 720 / 900 GRa GR DO gas electric dual fuel oven
Our oven had the same fault.
It turns out that the air intake was blocked.
The air intake is at the front, just below the bottom oven door. Some liberal sucking with a hoover sorted the problem instantly.
SOURCE: I have a stoves 720 gra with both ovens working ok
good day,
hope this link below will solve your problem.
ovens
SOURCE: Stoves 720 EF Electric Double Oven Model No
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
So if you have done all that and it still doesn't work, then the micro-switch could be faulty.
Best of luck
SOURCE: Hi Guys I have a Stoves
If the element and the indicator light both stopped working this suggests a problem with the power supply for the grill control. Either the grill control has no power going to it or it is faulty and requires replacement. If you are not sure what you are doing you'd better get a tech. to look at it, it can be fairly complicated for the untrained person.
