SOURCE: No Power
There is a main AC fuse on the power supply bd. and a couple of ciramic fuses on both the ysus bd and the zsus bd. This symptom most of the time means either the ysus bd, the zsus bd. or both have failed. Difficult repair for a customer and most likely will need to have a qualified tech diagnose the problem. Most times it is the ysus that has failed and a realistic price to repair this is from 400 to 500 dollars.
SOURCE: suddenly tripped off house
Hi akula, 200 ks to a fridgie, LG appliance, you must be in Australia;) Is it the earth leakage circuit breaker operating. If so, then you have a leakage problem to earth from the heater pad(not quite sure what that is, but this problem will need to be repaired. Am doing some research to see if there is anything that can be done without just getting a new fridge. Back to you soon.
regards
Graeme
SOURCE: vaillant boiler - no power
hi,
try bypassing the thermostat on the wall by tying the red and green wires together behind the thermostat. Go to the maufacturers website and study there. Call a local furnace place and ask to talk to one of the mechanics.
SOURCE: 32" visio tv tripping power throughout the house
I would have an electrician check to see if you have a grounding issue. Especially at the outlet that you have the power strip supply plugged in, Check to see what kind of your circuit panel is going to trip for electrical arc or electrical short. Newer panels should have both. Older just for electrical short. Have your electrician make sure your wiring is entirely copper, if it isn't and it's aluminum. Have him make sure the outlets are aluminum rated, and not designed for copper. Defintely check grounding. Good Luck
