What model Air Conditioner compressor has a 4 piston configuration?
  • Heating & Co... Master
  • 18,136 Answers
Central, automotive or refrigeration?
Posted on Feb 14, 2016
Testimonial: "This is for a project that requires a 4piston that turns the inner shaft.Thanks for any help:)"
  • Juanelle Burrell
    Juanelle Burrell Feb 14, 2016
    Doesn't matter. this is for a project that requires a 4piston that turns an inner shaft. Any help would be very appreciated.
  • Brad Brown Feb 15, 2016
    You are not likely to find one. 4 piston would be high volume and the would entail large unit usage of ammonia type coolant.
    Top Expert:
  • 53,757 Answers
Nothing in the small unit size ( 32.000 btu)
only company that made larger compressors were Carrier and they were for cold storage units
go google and type in---air condition compressors and see what site s show up
as you have not bothered to specify what system or application you have , it is difficult to be more precise
6ya staff
SOURCE:
I need a manual (Maintenance) for a Pulman Model 79/10L 440litre compressor. Piston type 7.5KW 1034KPa
cant find reference to pullman piston compressor
try contact us
on pulford site and see if they have a manual download
Piston Air Compressors for Sale Pulford Air gas
Jul 04, 2016 | Air Tools & Compressors
I need a 4 piston A/C compressor or a 4 piston hydraulic pump for a project. do you know which models have this
http://www.boge.com/in/artikel/download/Brochure304_EN_Piston.pdf
Devair/DeVilbiss Piston Air Compressors
www.centrair.ca/piston_compressors.html 5hp piston air compressor, 7.5hp piston air compressor, 10hp piston air compressor, 15hp piston air compressor, 25hp ... PUMP: 2 x 447 (2 stage 4 cylinder)
10HP 4 Cylinder 2 Stage Air Compressor Pump
https://www.eatoncompressor.com/10hp-4-cylinder-2-stage-air-compress... Solid cast iron 2-stage V-4 piston series pump, oil lubricated design to extend pump ... This is our 10 HP, 4 Cylinder, 2-Stage, air compressor pump with 43 CFM ... Compressor Stages‎: ‎Two Stage CFM @ 100 PSI‎: ‎43 CFM Compressor Type‎: ‎Bare Piston Pump Horse Power‎: ‎43 CFM
Petstar 4 - Ingersoll Rand
www.ingersollrandproducts.com > ... > PET Compressed Air Solutions Ingersoll Rand PETStar® 4 reciprocating air compressors offer durability and ... pistons with heavy-duty Class 40 cast iron cylinder construction; Piston rings and ...
Jan 31, 2016 | Air Tools & Compressors
Where can I find a piston ring for a Jobmate 8 gal air compressor?
was told coleman makes them and you could get parts through them colemanpowermate com
Feb 17, 2015 | Air Tools & Compressors
I have 2.5 Goodman heat pump, 3 yrs old, the sucsion pressure is 90 PSI, the discharge pressure is 180 psi. I am told the I have a bad compressor valve. Please, tell me how can I fix a bad compressor...
The piston is too large. Have a reputable heating and air technician install the proper size piston and this will correct the problem. Cost should be 150.00.
Sep 02, 2011 | Goodman CKL24AR24 Air Conditioner
Whynter Portable Air Conditioner Model: ARC-14S. Problem: It sounded as if something fell inside the unit while it was operating (cooling) then it started to vibrate horribly. The vibration is only...
Hi,Whynter Portable Air Conditioner has many moving parts, and they all make noise and cause vibrations. Some of these parts are more likely to causing shaking and loud noises, and sometimes this signals a larger problem, something to watch and scrutinize. If serious enough, it calls for a repair.
Loose Parts
Loose parts cause the majority of shaking and vibration noises in your air conditioner. A few of the most common loose parts include the air compressor, the piston rods and even the fan or blower unit itself. These noises are clunking, clanking sounds that occur along with a vibrating action. The only method of repair is a complete compressor replacement, which is a repair only a certified air conditioner technician is qualified to make. The compressor is a fully sealed component, so individual parts in the compressor cannot be repaired.
Fan Blades
Fan blades cause noise, shaking and vibrations even when properly secured. If fan blades contact the exterior structure of the air conditioner due to a bent fan blade or broken and misaligned grate, a constant, repetitive noise and vibration results, which sounds like a ticking or banging from the interior of the air conditioner. Vibration in this case is limited but still present.
Mounting Brackets
When an air conditioner shakes, there is a problem with the mounting brackets. These brackets hold the air conditioner compressor steady as it operates. Normal vibrations and shaking would otherwise occur without these brackets. A loose mounting bracket causes the air conditioner to rock back and forth and creates a clanking sound. As the compressor starts up, this rocking and clanking sound begins, resulting in a very loud and fast vibration and noise. It also occurs when the unit shuts down.
Other Sounds and Vibrations
Sometimes air conditioners squeal, hiss, hum or screech. Each noise is often accompanied by a vibration. Humming sounds along with a vibration may indicate a bad capacitor, the electrical part responsible for starting the machine. Hissing sounds tend to indicate a pressure problem while screeching and squealing sounds are fairly common in window air conditioners and in central air conditioners. This sound is also a result of the compressor motor. It usually starts when the unit turns on and continues through its normal operating cycle. Vibrations always occur in the air conditioner due to moving parts and the compressor motor's operation.
Hope it helped..
Aug 18, 2011 | Whynter Portable Air Conditioner
When you switch to compressor it just hum, motor not running. why?
It's because of compressor taking high amphs. Due to weak of capacitor, or loose wiring. And also piston inside the compressor struck. Replace capacitor and try after rectifying loose wiring, if any.
Dec 15, 2010 | Panasonic CW-XC143EU Air Conditioner
Need a rod for an oil run porter cable air compressor model c3151
Ok, the post shows 2 model numbers, so I will provide links for both. Be sure to only pay attention to the model number you actually have.
For a model C3151, an oilless compressor, the only way to get the connecting rod is by buying a piston kit, there is no individual replacement. KK-4835 is the part number and it runs about 50.00.
It can be purchased here.
http://www.ereplacementparts.com/piston-cylinder-and-ring-replacement-kit-p-58708.html
Now if you have a C3551, an oiled compressor, the entire Eccentric Rod Assembly will have to be replaced. The part number is Z-D22207 and it runs about 100.00.
http://www.ereplacementparts.com/assembly-conrod-eccentri-p-62701.html
I hope this helps.
Dec 04, 2010 | Porter Cable 4 5 Gallons 150PSI Job Boss...
Compressor continues to run for another 5 minutes after the fan has stopped. Air conditioner cools fine.
sounds like the "extended run timer" is somehow hooked to the compressor circuit instead of the blower fan circuit. This may appear after installing a programmable or digital thermostat. check configuration.
May 16, 2010 | Dometic Rooftop RV Air Conditioner
PROBLEM WITH DOMETIC RV ROOFTOP AIR conditioner
Check at the compressor terminals between the Red and the terminal for the overload protector to see if you are getting power to the compressor on startup.
Jul 23, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
47 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
