Something blocking the overfill sensor inlet. This video has fixed it for thousands of people.
https://m.youtube.com/watch?v=V04PvdyWVTM
The OE or Overflow Error code.
The water inlet valve is an electrically-controlled valve that opens to allow water to enter the dishwasher. Depending on the model, the valve stays open either for a set length of time or until the dishwasher has enough water. However, if the water inlet valve doesn't shut off after the dishwasher has enough water, the dishwasher will overflow. If water drips into the dishwasher when the door is open, or if water collects at the bottom of the dishwasher while it is not use, you may need to replace the water inlet valve.
SOURCE: Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Good Luck!!!
