You can follow these procedure to clear the Jammed on your printer.
1.Remove the paper tray (
Installing and removing the paper tray).
2.Disconnect the power from the printer dock for 5 seconds, then reconnect the power.
Carefully remove the paper if it does not automatically eject.
IMPORTANT:Check the paper slot on the back of the printer dock for jammed paper:
3.Remove the paper supply from the paper tray. Carefully "fan" the paper to keep the sheets from sticking together.
4.Reload the paper tray. Do not exceed the fill line.
5.Re-install the paper tray, then press to resume printing.
You can also check this link for other troubleshooting tips that you can do if you have problem with the printer, just click
HERE.
How to remove printer tray from kodak 5300
