Hobart HL600 Legacy Stand Mixer Logo
Posted on Jul 15, 2009
We have a H600T mixer. When you push the stop button it will stop. But when you let go it will cut back on.What can be wrong. My email is [email protected]
traboH Mr
Level 1:
  • Contributor 27 Answers
  • Posted on Sep 19, 2009
traboH Mr
Contributor
Level 1:
Answers
27
Questions
Helped
13617
Points
41
Check for debris around the start button. It's common for flour and such to build up between the plastic button and the switch plate causing the button to stick in and the start switch to remain engaged. It may be necessary to remove the switch in order to clear away all the debris. Especialy if the rubber boot is missing from the button.
SirFixolot
Level 1:
  • Contributor 3 Answers
  • Posted on Jul 18, 2009
SirFixolot
Contributor
Level 1:
Answers
Questions
0
Helped
968
Points
Look for a stuck relay or contactor that is siezed closed.
1helpful
60 qt Hobart mixer H600T makes buzzing noise and won't spin. The hook seems blocked, can't spin it manually. Opened the top part and everything seems fine. What can it be and how to fix it? Thank you
call in an electrician as it may be the start/run capacitor for the motor ( indicated by motor humming but not running)
the gearing will make it very difficult to turn the blades by hand as the motor will be spinning at either 1400 rpms or 2400 rpms down to around 50 rpms for the blades
Why does my Hobart 30 quart mixer cut off after 15-30 seconds of mixing?
The small button that pops out is your over load protection for the electrical motor
There might be a phase missing from your power supply.
The motor might have a problem.
Or the gearbox is faulty and couses the motor to struggle to turn and thst is the reasons for a over load protection to trip
Jul 26, 2015 • Food Mixers
Hobart h600t . Makes noise on speed 3 and trips on overload. I checked start cap all electrical components all look normal.
I'm having the same problem cap and all look good but still the motor won't run and the the overload trips the breaker
HELO I recently purchase a 460V H600T hobart mixer 2.5 AMP/ 3 PHASE but unfortunatly our bakery only provides 110V or 220V what are my option??
The machine can be internally rewired for 220 3 phase. Call your local Hobart office and have them come out and take care of it.
H600t has a grinding sound when engaged
All you can do is take to top off and look inside. Look for damaged gears, shafts that move sideways slightly (or more than slightly) when power is applied, that sort of thing.
Also look for a worn gearshift. Be sure that it engages fully in each gear- observe and see how the mechanism works, there's an overrun clutch with dogs that can drag if the shifter is worn or out of adjustment.
There's not much to go wrong with a Hobart, they seldom fail and are generally easy to repair. Replace the grease while you're in there, if you don't like bearing grease call around and find some food grade grease, a lot of auto parts stores carry it now.
lp
What type of oil goes in trans of h600t mixer
the oil part# is 102973-71, you can go to any hobart office in your area to get
Dec 09, 2009 • Food Mixers
2answers
Hobart H600 wont shut off
Sounds to me like the start switch contacts are welded shut.If you have a multimeter set it to ohms,remove 1 wire from the switch,put your meter leads across the switch and if you get a reading that switch is bad.If you dont get a reading i would check the side switch on the contactor.Im a hobartt tech and repair these mixers alot.Let me know.
7helpful
2answers
What type of oil is used in hobart-h600
hi / I have to chang hobart mixer h600t oil seal on the end of dough hook , but not sure how ? please let me know if any one
knows about that
Jun 23, 2008 • Food Mixers
2answers
Hobart mixer
Hi,im a hobart tech and know all these mixers well.What kind of mixer are you looking to write about?The differences are the sizes of bowls as 20qt,30qt,40qt,60,qt,80qt,140qt.Pick a mixer and i will write YOUR paper,but i want a fixya rating in return.
Top Hobart Food Mixers Experts
vince
NOEL
NOEL
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
