Find "Customize"
Press the Navigation key.
Select Profiles.
Highlight General.
Press the Left selection key.
Select Customize.
Select ring tone
Highlight the field below "Incoming call".
Highlight the required ring tones to hear them.
Once you've found a ring tone you like, press the Navigation key.
Return to the home screen
Press Disconnect to return to the home screen.
Hi David.
if the all setting are ok??
then you have to check its ringing tones ,simply go to ringing tones under the settings and try to change the tone and you can increase the volume in this menu too.
if no ringing ton hear.
it is hardware issue.
regards.
nuwan
Hi, what makes it when disconnected to ear piece. When ear piece is not in my ear, you can not hear the phone ring is because the ringer of the phone that makes you know when there is an incoming call on your cell phone or a message alert tone on your cell phone is damaged and does not work and makes sound to notify you .
The ringer is a tiny speaker inside the cell phone that allows you to hear incoming call from your cell phone You will need to replace the ringer inside the cell phone ....
When you replace with another ringer (speaker inside the cell phone),phone will be Ok again.
Would advice that you contact an expert in phone repairs for asistance,that will do you good to prevent more damaged on the phone...
You can change the incomming ringing for your set by pressing feature *6 , press the next key to select the ring type and ok to store the new ring tone.
The problem may be a short on your line. (Have the local Teleco check your line.) If you have other phones, you may want to check them for dial tone(DT) when this happens. If you have no DT, your cordless may be the problem...unplug, and let charge overnight. If problem continues, replace the battery in cordless, or discontinue use.
