BDP5506, HTS5506, BDP3306, HTS3306, BDP3506, HTS3506, BDP3106, HTS3106
Press the [Home] button on the remote. Then select [Setup]>[Advanced Setup]>[Restore defaults settings]>[Reset Network Setting]>[Yes]
BDP3406
Press the [Home] button on the remote. Then select [Setup]>[Advanced]>[Restore default settings]>[OK]
BDP7320, BDP7520, BDP5320
Press the [Home] button on the remote. The select [Settings]>[Factory Default]>[Network Settings]>[Yes]
http://www.p4c.philips.com/cgi-bin/cpindex.pl?ctn=BDP5506/F7&hlt=Link_UserManuals&mid=Link_UserManuals&scy=US&slg=AEN
SOURCE: I need to hard reset my Philips Blu ray player BDP 2015 can someone help
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand devices are given. Never forget to exit the service mode, after all adjustments have been done.
