Need pinpoint tests to check internal components
Best to start at the beginning. You have it connected properly? Are you using the line level, direct or speaker inputs? What output on your receiver are you using?
Have you adjusted the volume control?
If you have everything correct, are you the original owner? It's an older model so if you are the original owner what happened when it stopped working? Noises, fade out, just wouldn't turn on one day.
Are you capable of doing some minor electrical work? Can you read a schematic? Can you recognise electrical parts? If the answer to any of these last three questions is no, you need to take it to someone that has the ability to do electrical repairs. If the answer to all three is yes you can fix this yourself.
